*** AutoCAD Stuck at Checking License? - FIX For Visual C++ & .NET Framework ***
Message 1 of 1
After a large Windows Update over the weekend my AutoCAD and Vault would not work past "checking license"
Other Symptoms:
  • Could not revert to restore point - Windows Explorer would crash
  • Could not use windows update - error code 80072efe
  • .Net Framework "Unhandled exception has occured" error with log-off/restart/shut down
  • "Another Installation in Progress" for repairing .Net Framework
  • Shutdown process takes hours
  • Other various issues and computer lag
Troubleshooting:
  • CCleaner - "Repairs" found issues but does not fix
  • Stopping Windows Update Services via cmd - No Fix
  • Deleting AutoCAD trusted storage date (in flexnet) - No Fix
  • Blocking and Turning off Firewall - No Fix
  • Safe Mode - No Fix
Fix:
After a lot of research and troubleshooting, I put 2 and 2 together and realized my main issue was with the Visual C++ Libraries and the .Net Framework. I wasn't able to do anything with them in the programs and features so I had to look elsewhere. I finally found this > http://www.majorgeeks.com/files/details/visual_c_runtime_installer.html, which is an all in one removal & installation tool.
Running this tool successfully was only achievable through safe mode. Run the program, restart the computer into normal mode, and voila! AutoCAD & Vault no longer hang at checking license and both work fully. All my other issues went away as well and the computer seems to work better than ever!
Replies (0)
