AutoCAD Script Errors and License manager failure
Message 1 of 13
I have AutoCAD 2018.1.2 and AutoCAD 20191.2 installed on a Windows 10 version 1703
I continue to get 2 script errors and license manager errors
I can run fine for a week or so then they both fail with the same errors.
I had worked with the Autodesk techs for 3 weeks but they were not able to find the cause.
They had me do complete uninstalled (Per there complex list of things to uninstall)
Reinstall. update all service packs.
They would run fro a week or so then fail
I've also worked with our software vendor techs and they are unable to solve this.
When this happens I'm givin new authorization numbers. This will work for a week or so and then they fail once again.
These are standalone installs.
Specs:
Windows 10 enterprise ver 1703  (Local IT wants to try ver 1809 to see if this help
16 gig Ram
500 Gig SSD
Corporate Network
There are 2 other users that have the same problem.
I've tried EVERY suggestion on these forums and internet without success.
I've removed the "Language" at the end of the Shortcut ICON. did not help
I've had corporate IT White list all AutoCAD file types from McAfees "On Access Scanning" No help!
Just hoping someone out there has seen this and found the cause.
Thank You !
Ron
Very large world wide company
Replies (12)
Message 2 of 13
natasha.l
Hello @Anonymous,
Thank you for posting in the forums.
Please share the error message you are receiving. Thank you.
Please "Accept Solution" if a reply or replies have helped resolve the issue or answered your question, to help others in the community.
Message 3 of 13
Here are the errors I get for both AutoCAD 2018.1.2 and AutoCAD 2019.1.2 versions
2018 script Error-1.PNG2018 script Error-2.PNGAutoCAD 2018 License error.PNG
Message 4 of 13
natasha.l
Hello @Anonymous,
The script error indicates this is an issue with the language selected for the operating system & the application.
Solution:
Right-click the AutoCAD 2018 icon, go to "Properties" > "Shortcut" tab, delete the /language "en-US" from the Target text box and then start the program.
Let us know how it goes.
Message 5 of 13
Natasha,
I indicated in my first message I've already y done this for both versions.
I've done this several times over the last 6 weeks after reinstalling.
This does NOT solve the problem.
Still get those 2 script errors and then the license manager error.
Ron
Message 6 of 13
Here is what the short cut ICON properties looks like now:
Message 7 of 13
natasha.l
Hello @Anonymous,
If this solution did not work then we can move on to the next steps. These errors indicate a URL is trying to be reached for the application to run properly, so this is an access issue.
What makes these selected computers different then the others that can run the application without these errors? Do these script errors appear after a specific event or function, so when exactly? Does the operating system indicate a error in the system logs etc.?
Please review the following:
  • Connection issues Adjust Lan Settings, Proxy Settings & etc. , or try a different network location
  • Try running the application under a Windows profile with full Administrator privileges
  • In Microsoft® Internet Explorer, set the security level settings to the default level for all zones
  • Apply all service packs, critical updates, and security updates available for Internet Explorer
  • In Internet Explorer, empty the Temporary Internet Files folder.
  • Clean out your temporary folders for your user account and the operating system. (To access the Temp folder, enter %temp% in the Address box in Windows Explorer)
  • Download and apply the following update for Java: Java Update
  • Make sure your Internet Explorer meets our system requirements
Keep us posted.
Message 8 of 13
Natasha,
All those things have been addressed and the problem continues.
I've been working with our corporate IT dept. to see if there is some "Policy" that is stopping AutoCAD from obtaining our licenses (When AutoCAD is loading it always stops at "Checking License") then I get 2 script errors and license manager error.
Where does AutoCAD look for in obtaining our license information? (web site? Web server? License Server?)
What can I tell out IT dept. exactly where it is looking for the licenses????
Ron
Message 9 of 13
Natasha,
I see our computers have "FlexNet" installed.
Is this something a Standalone AutoCAD uses?
Or is Flexnet something that our company uses????
Message 10 of 13
Mark.Lancaster
@Anonymous
Are these product based on a carried over perpetual license or subscription?
Is this happening on every machines or only certain ones?
If you unplug from your network, wifi, internet, router and etc and launch the product does it work without any issues?
Update:  You also indicate a specific release version of these products..  Did the product working flawless before applying these updates or they were installed, updates applied and now the issue is there?
Mark Lancaster
Message 11 of 13
Mark,
Since this is a Huge corporation many things are not allowed on ANY computer
Can not disable McAfees, Can not Edit the registry.
Currently there are 2 users experiencing the errors.
These errors typical occur every 7-10 days.
We can get new authorization codes from our dealer and we are good for another 7-10 days.
This has been going on now for almost 6 months.
Yes these were continuation of Maintenance plans going back to version 2012
We will be going to another plan Subscription the first of the year.
Our IT dept has made several changes to "Policies" and have added Whitelist of AutoCAD file types to the on access virus scanning.
Autodesk techs were not able to give us a solution.
We have been working with our Dealer and they have not offered a solution.
I have tried EVERY thing that they both have suggested. All versions have the latestes updates installed
I have done complete uninstalls (With explicit instructions for Autodesk to ensure ALL files and folders are removed)
This has not solved the problem
Our IT dept continues to look for solutions but have not found one.
From what I see happening is when the software is loading, I see one instance of "Checking License" it continues and then later I see if "Checking License" this is where it stops and gives the 2 script errors and final a license manager error. Once this happens I can never get it run again later that day or another day with out getting a new authorization number from our dealer.
Message 12 of 13
I know how important it to Autodesk to stop illegal use of their software by having the software confirm it is a legitimate license.
I've been working with Autodesk techs and software vendor now for 6 months with not solution to our problem
If indeed this is our network problem and our IT dept can not find the cause.
It would make sense that Autodesk could code a piece of software that can be used in lew  of AutoCAD checking for license every time it starts. It would only work with  verified licensed software provided by the Autodesk certified dealers. It would never work for illegal copies.
I have worked for this company for 16 years and have ALWAYS had legitimate AutoCAD software (Purchased from an Authorized dealer)
Message 13 of 13
Well after about 6 months of Script errors and license manager errors, I final found the cause of all of these problems.
I normally migrate all my settings from the previous version and have never had any problems with everything working correctly.
This was a new install of Full AutoCAD 2019
Someone in our local IT group noticed that the 2 errors showed that it was looking at my network assigned folder.
So I began to scour through all of the settings and default folder locations. Nothing was found.
So one day I was on another workers computer that had used my Migrated ZIP folder to create the same workspace.
This had always worked also.
Upon looking at the options menu under the  "Plot & Publish" tab. I saw in the "Plot to File" location was my personal network folder !!!! YIKES  that can't be correct.
So now I know that when you do a migrate settings it is not recommended for others to use your file.
So I began to set every ones "Plot to File" locations as C:\Autodesk
I have been error free now for over 4 weeks
I will be retiring on Friday Feb. 1st   After 30 years of AutoCAD work. I was blessed with the companies that allowed me to do this work and excel at a job I only dreamed of.
Thank you Autodesk !
