AutoCAD Map 3D 2018 installing on Windows 2016 Server for deploying XenApp
Will AutoCAD Map 3D 2018 run on Windows 2016 Server?
In the requirments for OS support for the application there is nothin about Windows Server.
Its only written that the license server will run on Server 2012 or lower.
Does anyone allready have tested this?
natasha.l
Hello @Anonymous,
I have found some better system requirements for you to review, that cover server requirements & you should also take a look at the Autodesk Citrix supported products page, AutoCAD Map 3D 2018 is not listed.
Take a look at the following: AutoCAD Map 3D 2018 System Requirements
Let me know if this was helpful.
Please "Accept As Solution" if a reply has helped resolve the issue or answered your question, to help others in the community.
This information does not give extra info.
it is the same what i allready found.
The point is in the requierments for the OS it say Windows 7 SP1, Windows 8.1 with update KB2913955 and Windows 10
And at Network it gives only info for the license manager that it will run on Server 2012, 2012 R2, 2008 and 2008 R2.
For optional Software it tells it will run on Citrix XenApp 7.6, Citrix XenDesktop 7.6 so to me the Citrix Ready page is then not updated, else it is not correct to tell on the requirments page that it runs on Citrix 7.6 ..........
On our clients citrix platform they want to run Windows Server 2016.
But in the requirments nothing is mention about running AutoCAD on Sever software.
Previuosly it was written in the requirments but now it is not mention anywhere ....
At this point we are running AutoCAD Map 3D 2016 correct on Citrix XenApp 6.5 with Windows Server 2012.
natasha.l
Hello @Anonymous,
I will reach out to see if this needs updating & let you know if I hear back.
Sorry for the inconvenience. Smiley Happy
natasha.l
Hello @Anonymous,
I reached out to the team that determines the system requirements for AutoCAD Map 3d, asked about a Windows 2016 Server with Citrix 7.6 & if the system requirements are up to date.
This was the responce:
"Map 2018 System Requirement is updated to date. It supports Citrix 7.6. Furthermore, we use the same testing environments with AutoCAD Citrix testing.
https://knowledge.autodesk.com/support/autocad-map-3d/troubleshooting/caas/sfdcarticles/sfdcarticles/System-requirements-for-AutoCAD-Map-3D-2018.html"
Hope this was helpful & thanks for posting.
