AutoCAd LT 2022 on my mac Crashing
I installed AutoCAd LT 2022 on my mac. When I click of the AutoCAD LT 2022 icon to open the application, I get a crash report. Can anyone help me out with this please?
The crash report has the following:
"Termination Reason: DYLD, [0x1] Library missing
Application Specific Information:
dyld: launch, loading dependent libraries
Dyld Error Message:
dyld: Using shared cache: 0781246A-4850-3632-8FD5-CCB70AA8F9B8"
Library not loaded: @rpath/AcGeomentObj.dbx/Versions/A/AcGeomentObj
Referenced from: /Applications/Autodesk/*/AutoCAD LT 2022.app/Contents/MacOS/AutoCAD LT 2022
Reason: image not found
natasha.l
Hello @Anonymous,
 It seems the installation can not get past the content libraries, to avoid this try a different installation method. If this content was not installed as expected, review the steps below:
  1. Be sure to sign-in as Administrator, verify permissions on your Mac
  2. Temporarily disable security settings on a Mac
  3. Adjust the Proxy Settings
  4. Make sure you have an uninterrupted & high-speed connection to the internet, if the connection is limited use a different WIFI network
  5. Conduct a Clean Uninstall on your Mac
  6. Use a Browser Download Method in your Autodesk Account or via the Autodesk Virtual Agent
  7. Then try to install AutoCAD LT for mac again
Please "Accept Solution" if a reply or replies have helped resolve the issue or answered your question, to help others in the community.
