AutoCad LT 2013 GPO install issue gpo.mst
martin_franc
Message 1 of 20
martin_franc
I made a new administrative package, together with the merger with SP1.1. I'm going to put to the test policy (acadlt.msi) and voila. Add the first change script can (ACAD-ACLT2013ENSP1.1x64.mst), the second standard can not (gpo.mst) - AD resist "An error occured Accessing the software installlation data in the active directory". Standard message So when I try to cram wrong somewhere mst, missing information about the version of the application. Was already the same problem with this Civil 2013.
Replies (19)
Message 2 of 20
hashim.mundol
We tested this on our side,We are not able to re-produce this on 64bit Image of AutoCAD LT 2013.
Can you try to add this using Active Directory client running on another OS.(2003/Xp etc..)
If my post answers your question, please mark it as an Accepted Solution, so that others can find answers quickly!
For more tips & tricks: http://upandready.typepad.com
Hashim Mundol
Autodesk Product Support
Autodesk, Inc.
Message 3 of 20
martin_franc
I try do this directly from AD console on W2K8R2. Domain and forest functional level is Windows Server 2008 R2. I think I'll do one more attempt. I download the English installation package and create LT2013 x64 description step by step.
Message 4 of 20
martin_franc
Steps 1 to 12 :create a standard network image (LT2013 x64 EN package downloaded today from Autodesk) + merge with SP 1.1
1) Run setup as administrator
2) Create deployment
3) Conf. name and network path, standard installation settings
4) EULA
5) Serial number
6) Settings part1 (change - deselect Display Welcome screen... in User Preferences)
7) Settings part2 (change - select location of SP and set option "Merge...")
8) Settings part3 (change - deselect "Enable live updates")
9) Settings part4 (change - select "Allow users to recieve...")
10) Making of network image with SP1.1
11) Network image completed
12) Network location ready
Step 13-25 Our AD
prerequisites:
A Global security group named G SWITestAPP
A Group policy object named SWI TestAPP
13) A tree of group policy in GPMC where is "GPO SWI TestAPP" (a clear gpo without settings)
14) remove "Authenticated Users" group from delegation/filtering GPO SWI TestAPP
15) add group "G SWITestAPP" to security filtering of GPO "SWI TestAPP" with "Apply Group policy" Permitions
16) status of GPO changed to "User configuration settings disabled" because instalation used only part of machine policy
17) Start editing GPO "SWI TestAPP"
18) Configure new package
19) Select msi file from network image
20) Selected method: Advanced
21) Configuration of... Name
22) Configuration of... Deployment and Advanced options
23) Configuration of... Modifications - set 1st mst file (aclt-nameofimage.mst)
24) Configuration of... Modifications - set 2nd mst file (gpo.mst)
25) and click OK = Error
Message 5 of 20
martin_franc
Steps 13-17
Message 6 of 20
martin_franc
Steps ...to 25
Message 7 of 20
hashim.mundol
What is the error in the event viewer ?
Hashim Mundol
Autodesk, Inc.
Message 8 of 20
martin_franc
App log chronologically :
og Name:      Application
Source:        Software Installation
Date:          26.9.2012 10:39:45
Event ID:      119
Task Category: None
Level:         Warning
Keywords:      Classic
User:          N/A
Computer:      xxx
Description:
Software Installation encountered an unexpected error while reading from the MSI file \\sph00\ADIB\Test\ACLT2013ENx64SP1.1\AdminImage\x64\acadlt\acadlt.msi.  The error was not serious enough to justify halting the operation.  The following error was encountered: The operation completed successfully.
Log Name:      Application
Source:        MsiInstaller
Event ID:      1040
Task Category: None
Level:         Information
Keywords:      Classic
User:          EGEM\damf_01
Computer:      xxx
Description:
Beginning a Windows Installer transaction: \\sph00\ADIB\Test\ACLT2013ENx64SP1.1\AdminImage\x64\acadlt\acadlt.msi. Client Process Id: 6176.
Date:          26.9.2012 10:39:47
Event ID:      1042
Task Category: None
Level:         Information
Keywords:      Classic
User:          SYSTEM
Computer:      XXX
Description:
Ending a Windows Installer transaction: \\sph00\ADIB\Test\ACLT2013ENx64SP1.1\AdminImage\x64\acadlt\acadlt.msi. Client Process Id: 6176.
Source:        Microsoft-Windows-RestartManager
Date:          26.9.2012 10:39:46
Event ID:      10000
Task Category: None
Level:         Information
Keywords:
User:          EGEM\damf_01
Computer:     XXX
Description:
Starting session 0 - ‎2012‎-‎09‎-‎26T08:39:46.432468600Z.
Event ID:      10001
Task Category: None
Level:         Information
Keywords:
User:          EGEM\damf_01
Computer:      XXX
Description:
Ending session 0 started ‎2012‎-‎09‎-‎26T08:39:46.432468600Z.
Date:          26.9.2012 10:42:26
Event ID:      1040
Task Category: None
Level:         Information
Keywords:      Classic
User:          EGEM\damf_01
Computer:      XXX
Description:
Event ID:      1042
Task Category: None
Level:         Information
Keywords:      Classic
User:          SYSTEM
Computer:      XXX
Description:
Log Name:      Application Source:        Software Installation Date:          26.9.2012 10:42:26 Event ID:      110 Task Category: None Level:         Error Keywords:      Classic User:          N/A Computer:      xxx  Description: Software Installation was unable to generate the script for \\sph00\ADIB\Test\ACLT2013ENx64SP1.1\AdminImage\x64\acadlt\acadlt.msi.  The following error was encountered: Error applying transforms. Verify that the specified transform paths are valid.
Log Name:      Application Source:        Software Installation Date:          26.9.2012 10:42:26 Event ID:      101 Task Category: None Level:         Error Keywords:      Classic User:          N/A Computer:      xxx Description: Software Installation encountered the following error: Error applying transforms. Verify that the specified transform paths are valid.
its all
Message 9 of 20
hashim.mundol
could you please try without SP1 ?
Hashim Mundol
Autodesk, Inc.
Message 10 of 20
martin_franc
You think LT2013 without SP1.1...? Yes i have, yes its working. I have 50 clients in domain with LT2013EN (+CZ lang pack) distributed via AD/GPO. Its about 80 installations (clients have laptops and workstations). And versions LT2012/LT2011 with SP2 too.
Message 11 of 20
hashim.mundol
hi Martin
Thanks for testing, it. I have re-produced the issue in the lab. and found a work around.
Please use the attached mst (gpo_for_sp1.mst, attached as zip) file instead  of gpo.mst against acadlt.msi
For other msi files (AcadLTLP.msi,AcadLTPS.msi) pelase use the original gpo.mst file.
Please let me know if this helps in deploying AutoCAD LT 2013 Sp1.1
Hashim Mundol
Autodesk, Inc.
Message 12 of 20
martin_franc
Thanks, maybe I'll try it later today.
It is also applicable to the x86 version of ACLT2013 (SP1.1)? It has the same problem.
Message 13 of 20
hashim.mundol
Yes it should work on 32 and 64 bit.
Hashim Mundol
Autodesk, Inc.
Message 14 of 20
martin_franc
Meanwhile... I found same issue in AutoCad 2013 and SP1.1...
Message 15 of 20
martin_franc
I tested it on virtual W7Px64 and it appears that it work (gpo_for_sp1.mst for LT2013). Good job :). Thank You.
Message 16 of 20
hashim.mundol
thanks for testing,
same file should work for AutoCAD 2013  SP1.1 too, I haven't tested yet..
Hashim Mundol
Autodesk, Inc.
Message 17 of 20
martin_franc
Really? Give me 30 minutes.... 🙂
Message 18 of 20
martin_franc
Thanks, works fine with ac&aclt2013. 🙂
Message 19 of 20
hashim.mundol
Thanks for confirming.
Hashim Mundol
Autodesk, Inc.
Message 20 of 20
mbhame
Good Lord, Thank You Hashim!!!
This file works for AutoCAD MEP 2013 w/SP1 embedded as well.
FTR Autodesk Technical Support (1-2 months ago) told me this was because my adminimage share path was excessively-long (even though it wasn't for the prior 5 years of builds).
