AutoCAD LT 2012 error code 1603
Message 1 of 9
when I open auto cad this and other error codes come up. as a result I have no tool bars I have to key in every command, and can't change layers
cant find the install disk to uninstall and reinstall
please help!
Replies (8)
Message 2 of 9
pendean
Community Legend
Community Legend
Are you trying to install the software?
Or did you recently change WIndows versions or something else on your network change? error code 1603 is an installation error more often than not.
Message 3 of 9
It may be but I cant find the installation disk to uninstall and reinstall
Message 4 of 9
pendean
Community Legend
Community Legend
Autodesk doesn't offer a download for LT2012.
Message 5 of 9
muriel.a
Hi @Anonymous,
I will open a support case and will send you the download links for AutoCAD LT 2012 directly by email.
Muriel Assuncao
Message 6 of 9
thank you that would be very helpful
Message 7 of 9
natasha.l
Hello @Anonymous,
The uninstall and reinstall may work and allow you to launch AutoCAD LT 2012. Not sure if this was a recent install or it has been installed for a while now, but the most common troubleshooting steps are listed below. Try looking at Event Viewer to review the latest events that have occurred on your computer (Windows Start> type in the seach> Event Viewer) to point you in the right direction.
  1. Make sure you have an updated graphics card driver on the manufacturer's website (Assign the correct Graphics Card - Step #8)
  2. Check the Operating System needed & the required updates by reviewing the system requirement for the software
  3. Update your product with the latest service pack or Hotfixes by visiting the Autodesk website or account
  4. Locate the install log or Control Panel for Microsoft Visual C++ have properly installed
  5. Reboot the computer
  6. In Windows Start, delete unnecessary items in the Windows Temp folder, but do not delete the Windows Temp folder itself. You can locate the Temp folder by entering %TEMP% in the Search bar of Windows Start
  7. Temporarily disable antivirus & firewall, use Task Manager to "End Task" feature to end the anti-virus software or other items that could be running in the background
  8. If the above does not resolve the issue continue & try Clean Uninstall of the product and downloaded via Autodesk Virtual Agent and install the product again
Keep us posted.
Please "Accept As Solution" if a reply has helped resolved the issue or answered your question, to help others in the community.
Message 8 of 9
natasha.l
Hello @Anonymous,
I wanted to check-in with you, I hope you were able to resolve the issue.
Message 9 of 9
yes thank you
