AutoCAD Licensing error
pheroxgaming
pheroxgaming
Community Visitor
Community Visitor
I installed autoCAD and whenever I open it, I get a licensing error.
My license will end on 6 March 2026.
I logged in with my account in Autodesk, and even before logging in I had the same problem, so I don't think the problem comes from my account.
Please note that I don't have windows defender, I removed it for personal reasons, I don't think it's the reason though.
I followed the troubleshoot guide and the problem still persists.
Thanks in advance
vinodkl
Hello @pheroxgaming
Please download Autodesk Access and install it. Next, install all the pending updates shown in Autodesk Access. Once updated, restart your system, turn "off" Antivirus temporarily, and run AutoCAD as administrator to see if it helps.
ವಿನೋದ್ ಕೆ ಎಲ್( System Design Engineer)
Likes is much appreciated if the information I have shared is helpful to you and/or others.
Please mark "Accept as Solution" if my reply resolves the issue or answers your question, to help others in the community.
Simon_Weel
Check this out: "Licensing Error. A licensing error occurred..." when launching Autodesk software
As for Access - you can also NOT install Access and download any updates from you Autodesk Account page. Access is flaky at best...
mari.shimode
Hi @pheroxgaming, did the information provided answer your question? If so, please use Accept Solution so that others may find this in the future. Thank you very much!
Mari Shimode
