Hello @brian_whitcherC4G7G
I understand you are encountering the "Failed to initialize download manager" error when attempting to install your Autodesk product using the Install option on our website. You also mentioned that when using the Download, Direct Download, or Deployment options, the .exe file launches but closes after “Preparing” without an error message.
Based on our review, here are the steps that should resolve the issue:
1. Use the Autodesk Download Manager (Recommended)
Instead of selecting Install, choose the Download option from the product page.
This will download all required files before installation, avoiding the initialization error.
2. Temporarily Disable Antivirus/Firewall
Some security software may block the installer during the preparation phase.
Temporarily disable your antivirus and/or firewall during installation, then re-enable it afterward.
3. Run Installer as Administrator
4. Install from the Browser Download Folder
5. Use the installers below to test the installation
Make sure you download both installer files to the same location, then run either of them:
If using the .7z file – Unzip the folder first, then right-click Setup.exe inside the extracted folder and select Run as administrator.
If using the .exe file – Simply right-click the file and select Run as administrator.
For reference: "Failed to initialize DownloadManager!" when trying to install Autodesk software
