AutoCad Installation between different versions
nzisis
Message 1 of 9
nzisis
Community Visitor
Community Visitor
hello Everyone
We have an account with 3 AutoCAD subscriptions valid for 3 years.
We had an AutoCAD 2020 subscription in one PC. In this PC we signed out from AutoCAD and uninstalled the application.
With the same subscription we want to install autoCAD again but we do not find the AutoCAD 2020 application inside the account page instead we see AutoCAD 2024, 2023, 2022, 2021.
I want to ask two questions.
  1. Can we find and install AutoCAD 2020?
  2. With this valid account we have, we can install AutoCAD 2024, 2023, 2022, 2021 or we must find and install AutoCAD 2020?
Replies (8)
Message 2 of 9
rkmcswain
what does your subscription and T&C say?
Do you have access to 5 versions back?
Have you contacted your reseller?
We always download it and keep a copy so X years later we have it when they hide the download
Message 3 of 9
Valentin_CAD
@nzisis ,
This may help:
Note:
Select the "Mark as Solution" if my post solves your issue or answers your question.
Seleccione "Marcar como solución" si mi publicación resuelve o responde a su pregunta.
Emilio Valentin
Message 4 of 9
paullimapa
Contact Autodesk directly to download that version
https://www.autodesk.com/support/contact-support?&utm_medium=cpc&utm_source=google&utm_campaign=&utm...
Paul Li
IT Specialist
@The Office
Message 5 of 9
Simon_Weel
Is there something special about the 2020 version that doesn't let you use a newer version?
Message 6 of 9
mdavis22569
You can get 2020 and 2019 via AVA in your account portal.  Go to the question mark in the lower corner. Put in Download, and you can get the 2 older versions.
Mike Davis
Message 7 of 9
mdavis22569
NO you don't!
Mike Davis
Message 8 of 9
mdavis22569
NO you don't!
Mike Davis
Message 9 of 9
mdavis22569
Autodesk Assistant
12:01 PM, Nov 28, 2023
Hi! I can guide you to a solution or connect you with an agent.
What can I help you with?
Post-purchase support
Let's narrow your question down so I can show you relevant options. Select a topic below.
Downloads
Download software
  1. Your product might be missing from your Products & Services list in your Autodesk Account because:
    • Your subscription expired. To renew:
      buy online
    • This account doesn’t include the product. Sign in to a different account.
    • You are not assigned a seat. Contact your admin to request access.
    • Your purchase is still processing. For immediate access, we can help you download the product now.
  2. Find a product download
  3. Which product are you looking for?
Mike Davis
