AutoCAD freezing my system when startup or checking licence
Hello!
I'm tring to use AutoCAD but that software are freezing my system when startup, or when opening a file (small file), or when checking licence screen. I tried a few of things that I found here in forum:
- Uninstall all autodesk software and reinstall then.
- Install another AutoCAD version, like AutoCAD 2018 LT, AutoCAD 2017 and now AutoCAD 2018. All do the same problem.
- Cleanup my system with a tool like CCleaner.
- Disable all my Kaspersky software.
- Uninstall Warsaw.exe that is a bank software in brazil that have too much problem with others sotware.
- Reinstall/Repair my AutoCAD 2018 installation too many times.
- Execute as administrator.
Here is my system spec:
- Windows 10 PRO 64-bit, version 1909, compilation 18363.752
- Processor AMD FX-8350
- Graphics MSI ATI Radeon RX-580
- Memory 16 GB DDR3 Corsair
- Storage HP PRO SSD 500GB
- Motherboard Gigabyte 970A-D3
- Kaspersky Security Cloud
- Fresh install of Windows 10
DarrenP
go through all of this: https://knowledge.autodesk.com/support/autocad/troubleshooting/caas/sfdcarticles/sfdcarticles/Softwa...
DarrenP
rkmcswain
OP should be able to get all that done by 2035.
Yes i see that post before, but no lucky with fix my problem...but I dont follow all instructions, because some of the issues listed on this topic are not compatible with my issue, I just follow the AV and Licence part...and nothing happens.
Now my AutoCAD open normally, but is confusing, because that freezing happens sometimes, not all startups.
