AutoCAD Electrical 2016 .NET Framework error
Message 1 of 30
While installing Autodesk AutoCAD Electrical 2016 i get an error: .NET Framework 4.5 installed. AutoCAD Electrical 2016 cannot be installed without this component. See your system administrator for more information.
I successfully installed .NET Framework 4.5 before trying to install AutoCAD, i'm using Windows 10 so this might be the probem.
Thanks for any help in advance.
Replies (29)
Message 2 of 30
asburyj
I am afraid Windows 10 comes with a newer version of the .net framework which isn't compatible with our installers at this time
Jeffry Asbury
Message 3 of 30
No fix available for this yet?
Message 4 of 30
Same problem I am facing, unable to install Autocad Electrical 2016 on Windows 10. Windows 10 comes with .Net 4.6 which is not being rcognized by the Suit Installer.
Would appreciate anyones suggestions on how to bypass this issue.
Thank you
Message 5 of 30
Thanks for your answer. When is this update due to arrive?
Message 6 of 30
asburyj
I am afraid there is no information published yet on that.
Jeffry Asbury
Message 7 of 30
arshadmirza786
what the way u adopted to install the .net frame 4.5
pls. explane for us
Message 8 of 30
I have the same issue under win7 .NET 4.5, 4.5.1 and 4.6..
I tried to install .Net 4.5.1 manually, but the installer stopped.
Any ideas to solve this problem?
Best Regards
Message 9 of 30
asburyj
The problem is that the installer doesn't recognize the 4.6 version of the .net framework. You may be able to workaround the issue however by modifying the "version" registry entry in the registry key found at HKLM\Software\Microsoft\NET Framework Setup\NDP\v4\Client. If you switch that version number to 4.5 that should trick the installer into thinking you are the appropriate version, just remember to switch the value back to the 4.6 version number when you are done.
Jeffry Asbury
Message 10 of 30
This was happeneing to me under Windows 7 as well, but this did the trick and it installed without a hitch! Thanks.
Message 11 of 30
I have tried to change version but it is saying can't change the contents
Presently I am using windows10pro
please help me
thank u
Message 12 of 30
Hello, I am also having a similar issue in that I cannot change the registry value to 4.5.
I look forward to a solution, however I understand that Windows 10 will incur plenty of compatibility issues.
Message 13 of 30
How can I modifying the "version"?? If I try to swith the version I get a notice "version can not edit".
Message 14 of 30
asburyj
Try editing the owner of the registry folder and switching it from trusted installer to your account. That should allow you the permissions to make the change.
Jeffry Asbury
Message 15 of 30
thanks for ur advice
when i try to change permissions windows security is not allowing it to do.
plzz suggest me how to manuplate that windows secutity too. and i am using
kaspersky internet security antivirus is this cause any problem to change
the version
thank u
Message 16 of 30
asburyj
You probably need to change the ownership rather than the permissions. Here's a general guide on how to change the ownership in the registry. http://www.askvg.com/guide-how-to-take-ownership-permission-of-a-registry-key-in-windows/
Jeffry Asbury
Message 17 of 30
thankyou for your help. Smiley Happy
AutoCAD Electrical 2016 install:     check
BR
Message 18 of 30
Thanks asburyj. I have found the same solution in the internet. Now it works fine.
Message 19 of 30
Thank U very much u helped me a lot
successfully installed 🙂
Message 20 of 30
While a nice work around, AutoDesk should really work on getting an update issued. It isn't like Win10 just suddenly appeared.
