AutoCAD 2025 Freeze after Startup screen
he_dawoud
Message 1 of 18
he_dawoud
Hi everyone,
I'm experiencing a strange issue with AutoCAD 2025 on my Windows 10 machine. After the initial startup screen disappears, the program freezes for approximately 2 minutes before running smoothly.
I've already taken the following steps to troubleshoot:
  • Updated System & Drivers: Ensured my Windows 10 is up-to-date and installed the latest drivers for my AMD Radeon RX graphics card.
  • Clean Install: Performed a clean installation of AutoCAD 2025.
  • Cleared Temp & Cache: Emptied the temporary files and cache folders.
  • Reinstalled .NET Framework: Reinstalled the .NET Framework.
Unfortunately, the issue persists. I've also tried AutoCAD 2023 and 2024, and they exhibit the same freezing behavior.
Has anyone else encountered this problem? Any suggestions on how to resolve this would be greatly appreciated.
Thanks in advance,
Replies (17)
Message 2 of 18
paullimapa
Make sure you've downloaded & installed 2025.1.1 update.
Next in AutoCAD try setting GFXDX12 to 0, then close & restart AutoCAD.
If no difference, enter GRAPHICSCONFIG command and select another option under 2d Display Settings.
Paul Li
IT Specialist
@The Office
Message 3 of 18
he_dawoud
Dear Paul Li,
Thanks for the fast replay.
I followed the steps as mentioned but unfortunately the problem still exist. Even freeze time became longer (more than 3 min).
I think I could overcome this issue by installing new windows system.
Message 4 of 18
paullimapa
After AutoCAD 2025.1.1 finally opens do the following:
Enter at command prompt: GraphicsConfig
Do a screenshot and share the image here.
Also at command prompt enter: ABOUT
Do a screenshot of that as well and share the image here.
Paul Li
IT Specialist
@The Office
Message 5 of 18
he_dawoud
These are the screenshots.. Thanks for following-up
Message 6 of 18
paullimapa
Your setup is still using Directx12. Enter command Gfxdx12 and set that to 0. Then close and restart AutoCAD. Enter GraphicsConfig command again do a screenshot and share that here .
Paul Li
IT Specialist
@The Office
Message 7 of 18
he_dawoud
DirectX 12 persists due to reverting to default. I've attached screenshots demonstrating alternative settings: Gfxdx12=0 and GraphicsConfig in basic mode.
Message 8 of 18
paullimapa
any difference with these alternative settings?
Paul Li
IT Specialist
@The Office
Message 9 of 18
he_dawoud
It takes longer time lunch.
Message 10 of 18
paullimapa
So leaving Autocad setup as Directx11 is the same as Directx12?
Paul Li
IT Specialist
@The Office
Message 11 of 18
he_dawoud
Even it's better to leave it with DirectX12.
Message 12 of 18
paullimapa
Time to sign into your account and submit a troubleshooting ticket with autodesk
Paul Li
IT Specialist
@The Office
Message 13 of 18
simon_smithV9KAB
Did you come up with a solution to this problem?
Message 14 of 18
he_dawoud
Unfortunately I didn't come up with any solution. I feel the problem caused by windows. I'm pretty sure installing fresh windows will solve this problem 100%.
Message 15 of 18
StinkySally
I found this fixed my problem. It occurred when I upgraded windows 10 to windows 11.
https://www.autodesk.com/support/technical/article/caas/sfdcarticles/sfdcarticles/SQLDUMPER-EXE-wind...
Message 16 of 18
paullimapa
Not sure if this applies to AutoCAD and Windows 10:
Paul Li
IT Specialist
@The Office
Message 17 of 18
he_dawoud
Thanks for mention this article. However, I tried this method on AutoCAD and Windows10, but still not solving the issue.
I'm using AutoCAD, and after 20 years of experience, I've never encountered a problem that persists like this one.
Message 18 of 18
paullimapa
Have you tried creating a different Windows user profile with local administrator privileges then sign into Windows using that new account to launch your AutoCAD 2023, 2024 & 2025 to see if that makes a difference?
Paul Li
IT Specialist
@The Office
