AutoCAD 2022 deployment fails
DRamkissoon
Observer Observer
DRamkissoon
Observer
Observer
I created AutoCAD 2022 application from the website and deployed it in SCCM. Clients installation fails with error 0x87D00324(-2016410844)
sophia_lee
Hi @DRamkissoon
For product install:
- get the product_guid from the Registry in location 'Computer\HKEY_LOCAL_MACHINE\SOFTWARE\Microsoft\Windows\CurrentVersion\Uninstall' searching for the product name (it's stored in the DisplayName variable) and use the 'Windows Installer code' detection method in SCCM
NOTE: Please make sure to create a back up for registry key when you edit.
If you are keep facing this error, please contact Autodesk support for further help.
Hope this helps. Please accept this as 'solution' if this answers your question. thanks
Sophia, Lee
Sr Technical Support Specialist
Customer Technical Success APAC
DRamkissoon
Observer
Observer
I already have the GUID set as the detection method. It still fails.
