autocad 2018
autocad 2018
autocad 2018
kurulum esnasında kısa sürede kurulum bitiyor ve hiçbir dosya yüklenmemiş olup bu hatayı veriyor. yardımcı olur musunuz?
2018/10/25:21:21:31 burci LAPTOP-C23MGK0M === Setup started on LAPTOP-C23MGK0M by burci ===
2018/10/25:21:21:31 burci LAPTOP-C23MGK0M Path_Length: 158
2018/10/25:21:21:31 burci LAPTOP-C23MGK0M Current Directory C:\Autodesk\AutoCAD_2018_English_Win_32_64bit_Trial_en-us
2018/10/25:21:21:31 burci LAPTOP-C23MGK0M Launch
2018/10/25:21:21:31 burci LAPTOP-C23MGK0M CommandLine /PK 001J1 /SN xxx-xxxxxxxx /akamai /sid SESSION_ID /skipEULA /student /url "http://edutrial.autodesk.com/NET18SWDLD/2018/ACD/D7AC923A-BC24-471F-ABC1-E578C6B5D699/WI/AutoCAD_201..."
2018/10/25:21:21:31 burci LAPTOP-C23MGK0M Current Directory C:\Users\burci\AppData\Local\Temp\_AIF072.tmp
2018/10/25:22:21:45 burci LAPTOP-C23MGK0M === Setup ended ===
2018/10/25:21:21:32 burci LAPTOP-C23MGK0M === Setup started on LAPTOP-C23MGK0M by burci ===
2018/10/25:21:21:32 burci LAPTOP-C23MGK0M Path_Length: 158
2018/10/25:21:21:32 burci LAPTOP-C23MGK0M Current Directory C:\Users\burci\AppData\Local\Temp\_AIF072.tmp
2018/10/25:21:21:32 burci LAPTOP-C23MGK0M Launch
2018/10/25:21:22:36 burci LAPTOP-C23MGK0M Download Play SETUPMARKER http://edutrial.autodesk.com/NET18SWDLD/2018/ACD/D7AC923A-BC24-471F-ABC1-E578C6B5D699/WI/{13EDBFB0-2...
2018/10/25:21:22:39 burci LAPTOP-C23MGK0M Download Complete SETUPMARKER http://edutrial.autodesk.com/NET18SWDLD/2018/ACD/D7AC923A-BC24-471F-ABC1-E578C6B5D699/WI/{13EDBFB0-2...
2018/10/25:21:22:41 burci LAPTOP-C23MGK0M Download Play SETUP_CONFIG http://edutrial.autodesk.com/NET18SWDLD/2018/ACD/D7AC923A-BC24-471F-ABC1-E578C6B5D699/WI/{13EDBFB0-2...
2018/10/25:22:21:45 burci LAPTOP-C23MGK0M Download Complete SETUP_CONFIG http://edutrial.autodesk.com/NET18SWDLD/2018/ACD/D7AC923A-BC24-471F-ABC1-E578C6B5D699/WI/{13EDBFB0-2...
2018/10/25:22:21:45 burci LAPTOP-C23MGK0M Install CustomCallback Info Invoking custom callback for details: [SETUP] CB_FUNC=CustomPlatformCheck CB_SOURCE=C:\Users\burci\AppData\Local\Temp\_AIF072.tmp\Setup\AcSetup.dll
2018/10/25:22:21:45 burci LAPTOP-C23MGK0M Install CustomCallback Info Custom callback response: Status=0 SUCCECSS Title= Message= URLTitle= URLLink=
2018/10/25:22:21:46 burci LAPTOP-C23MGK0M PageOpen LaunchDialog
2018/10/25:22:22:38 burci LAPTOP-C23MGK0M PageOpen LicenseDialog
2018/10/25:22:22:38 burci LAPTOP-C23MGK0M PageOpen ProductInfoDialog
2018/10/25:22:22:38 burci LAPTOP-C23MGK0M PageOpen ProductSelectionDialog2
2018/10/25:22:31:07 burci LAPTOP-C23MGK0M PageOpen FullProgressDialog
2018/10/25:22:31:12 burci LAPTOP-C23MGK0M Download Play STARTMARKER http://edutrial.autodesk.com/NET18SWDLD/2018/ACD/D7AC923A-BC24-471F-ABC1-E578C6B5D699/WI/{13EDBFB0-2...
2018/10/25:22:31:13 burci LAPTOP-C23MGK0M Download Complete STARTMARKER http://edutrial.autodesk.com/NET18SWDLD/2018/ACD/D7AC923A-BC24-471F-ABC1-E578C6B5D699/WI/{13EDBFB0-2...
2018/10/25:22:31:15 burci LAPTOP-C23MGK0M Download Play VCREDIST2008SP1X64 http://edutrial.autodesk.com/NET18SWDLD/2018/ACD/D7AC923A-BC24-471F-ABC1-E578C6B5D699/WI/{13EDBFB0-2...
2018/10/25:22:31:23 burci LAPTOP-C23MGK0M Download Complete VCREDIST2008SP1X64 http://edutrial.autodesk.com/NET18SWDLD/2018/ACD/D7AC923A-BC24-471F-ABC1-E578C6B5D699/WI/{13EDBFB0-2...
2018/10/25:22:31:23 burci LAPTOP-C23MGK0M Installing Microsoft Visual C++ 2008 SP1 Redistributable (x64): "C:\Autodesk\WI\Autodesk AutoCAD 2018\3rdParty\x64\VCRedist\2008SP1\vcredist_x64.exe" /q
2018/10/25:22:31:31 burci LAPTOP-C23MGK0M Microsoft Visual C++ 2008 SP1 Redistributable (x64) return code: 1603
2018/10/25:22:31:31 burci LAPTOP-C23MGK0M Install Microsoft Visual C++ 2008 SP1 Redistributable (x64) Failed Installation aborted, Result=1603
2018/10/25:22:31:31 burci LAPTOP-C23MGK0M PageOpen InstallCompleteDialog
2018/10/25:22:31:44 burci LAPTOP-C23MGK0M === Setup ended ===
2018/10/25:22:34:29 burci LAPTOP-C23MGK0M === Setup started on LAPTOP-C23MGK0M by burci ===
2018/10/25:22:34:29 burci LAPTOP-C23MGK0M Path_Length: 158
2018/10/25:22:34:29 burci LAPTOP-C23MGK0M Current Directory C:\Autodesk\AutoCAD_2018_English_Win_32_64bit_Trial_en-us
2018/10/25:22:34:29 burci LAPTOP-C23MGK0M Launch
2018/10/25:22:34:29 burci LAPTOP-C23MGK0M CommandLine /PK 001J1 /SN xxx-xxxxxxxx /akamai /sid SESSION_ID /skipEULA /student /url "http://edutrial.autodesk.com/NET18SWDLD/2018/ACD/D7AC923A-BC24-471F-ABC1-E578C6B5D699/WI/AutoCAD_201..."
2018/10/25:22:34:29 burci LAPTOP-C23MGK0M Current Directory C:\Users\burci\AppData\Local\Temp\_AIBE60.tmp
2018/10/25:22:34:32 burci LAPTOP-C23MGK0M === Setup ended ===
2018/10/25:22:34:30 burci LAPTOP-C23MGK0M === Setup started on LAPTOP-C23MGK0M by burci ===
2018/10/25:22:34:30 burci LAPTOP-C23MGK0M Path_Length: 158
2018/10/25:22:34:30 burci LAPTOP-C23MGK0M Current Directory C:\Users\burci\AppData\Local\Temp\_AIBE60.tmp
2018/10/25:22:34:30 burci LAPTOP-C23MGK0M Launch
2018/10/25:22:34:31 burci LAPTOP-C23MGK0M Download Skipped SETUPMARKER http://edutrial.autodesk.com/NET18SWDLD/2018/ACD/D7AC923A-BC24-471F-ABC1-E578C6B5D699/WI/{13EDBFB0-2...
2018/10/25:22:34:31 burci LAPTOP-C23MGK0M Download Skipped SETUP_CONFIG http://edutrial.autodesk.com/NET18SWDLD/2018/ACD/D7AC923A-BC24-471F-ABC1-E578C6B5D699/WI/{13EDBFB0-2...
2018/10/25:22:34:31 burci LAPTOP-C23MGK0M Install CustomCallback Info Invoking custom callback for details: [SETUP] CB_FUNC=CustomPlatformCheck CB_SOURCE=C:\Users\burci\AppData\Local\Temp\_AIBE60.tmp\Setup\AcSetup.dll
2018/10/25:22:34:31 burci LAPTOP-C23MGK0M Install CustomCallback Info Custom callback response: Status=0 SUCCECSS Title= Message= URLTitle= URLLink=
2018/10/25:22:34:32 burci LAPTOP-C23MGK0M PageOpen LaunchDialog
2018/10/25:22:34:38 burci LAPTOP-C23MGK0M PageOpen LicenseDialog
2018/10/25:22:34:38 burci LAPTOP-C23MGK0M PageOpen ProductSelectionDialog2
2018/10/25:22:34:47 burci LAPTOP-C23MGK0M PageOpen FullProgressDialog
2018/10/25:22:34:47 burci LAPTOP-C23MGK0M Installing Network License Manager: ALLUSERS=1 INSTALLDIR="C:\Program Files\Autodesk\Autodesk Network License Manager\" ADSK_EULA_STATUS=#1 MUILANG=en-us SETUP_PACKAGENAME="Autodesk® AutoCAD® 2018" SETUP_PACKAGECODE={DD42F784-12DC-49EE-8045-600335BE940B} SETUP_UNINSTALLKEYS=1 SETUP_ISLANGUAGEPACK=0 SETUP_PRODUCTDEPENDENCIES=";;;;" PACKAGEUPI={D7AC923A-BC24-471F-ABC1-E578C6B5D699} ADSK_SOURCE_ROOT="C:\Autodesk\WI\Autodesk AutoCAD 2018" FILESINUSETEXT="" REBOOT=ReallySuppress ADSK_SETUP_EXE=1
2018/10/25:22:34:48 burci LAPTOP-C23MGK0M Install Network License Manager Succeeded
2018/10/25:22:34:50 burci LAPTOP-C23MGK0M Download Play STARTMARKER http://edutrial.autodesk.com/NET18SWDLD/2018/ACD/D7AC923A-BC24-471F-ABC1-E578C6B5D699/WI/{13EDBFB0-2...
2018/10/25:22:34:52 burci LAPTOP-C23MGK0M Download Complete STARTMARKER http://edutrial.autodesk.com/NET18SWDLD/2018/ACD/D7AC923A-BC24-471F-ABC1-E578C6B5D699/WI/{13EDBFB0-2...
2018/10/25:22:34:53 burci LAPTOP-C23MGK0M Download Play VCREDIST2012X64UPD4 http://edutrial.autodesk.com/NET18SWDLD/2018/ACD/D7AC923A-BC24-471F-ABC1-E578C6B5D699/WI/{13EDBFB0-2...
2018/10/25:22:35:23 burci LAPTOP-C23MGK0M Download Complete VCREDIST2012X64UPD4 http://edutrial.autodesk.com/NET18SWDLD/2018/ACD/D7AC923A-BC24-471F-ABC1-E578C6B5D699/WI/{13EDBFB0-2...
2018/10/25:22:35:23 burci LAPTOP-C23MGK0M Installing Microsoft Visual C++ 2012 Redistributable (x64) Update 4: "C:\Autodesk\WI\Autodesk AutoCAD 2018\3rdParty\x64\VCRedist\2012UPD4\vcredist_x64.exe" /install /quiet /norestart /log C:\Users\burci\AppData\Local\Temp\vcredist_x64_2012_UPD4.log
2018/10/25:22:38:17 burci LAPTOP-C23MGK0M Microsoft Visual C++ 2012 Redistributable (x64) Update 4 return code: 0
2018/10/25:22:38:17 burci LAPTOP-C23MGK0M Install Microsoft Visual C++ 2012 Redistributable (x64) Update 4 Succeeded
2018/10/25:22:38:19 burci LAPTOP-C23MGK0M Download Play UCRT http://edutrial.autodesk.com/NET18SWDLD/2018/ACD/D7AC923A-BC24-471F-ABC1-E578C6B5D699/WI/{13EDBFB0-2...
2018/10/25:22:38:43 burci LAPTOP-C23MGK0M Download Complete UCRT http://edutrial.autodesk.com/NET18SWDLD/2018/ACD/D7AC923A-BC24-471F-ABC1-E578C6B5D699/WI/{13EDBFB0-2...
2018/10/25:22:38:43 burci LAPTOP-C23MGK0M Installing Universal C Runtime (KB3118401): "C:\Autodesk\WI\Autodesk AutoCAD 2018\3rdParty\ucrt\AdUcrtInstaller.exe" /S
2018/10/25:22:38:43 burci LAPTOP-C23MGK0M Universal C Runtime (KB3118401) return code: 0
2018/10/25:22:38:43 burci LAPTOP-C23MGK0M Install Universal C Runtime (KB3118401) Succeeded
2018/10/25:22:38:45 burci LAPTOP-C23MGK0M Download Play VCREDIST2015X86 http://edutrial.autodesk.com/NET18SWDLD/2018/ACD/D7AC923A-BC24-471F-ABC1-E578C6B5D699/WI/{13EDBFB0-2...
2018/10/25:22:39:06 burci LAPTOP-C23MGK0M Download Complete VCREDIST2015X86 http://edutrial.autodesk.com/NET18SWDLD/2018/ACD/D7AC923A-BC24-471F-ABC1-E578C6B5D699/WI/{13EDBFB0-2...
2018/10/25:22:39:06 burci LAPTOP-C23MGK0M Installing Microsoft Visual C++ 2015 Redistributable (x86): "C:\Autodesk\WI\Autodesk AutoCAD 2018\3rdParty\x86\VCRedist\2015\vcredist_x86.exe" /install /quiet /norestart /log C:\Users\burci\AppData\Local\Temp\vcredist_x86_2015.log
2018/10/25:22:39:18 burci LAPTOP-C23MGK0M Microsoft Visual C++ 2015 Redistributable (x86) return code: 0
2018/10/25:22:39:18 burci LAPTOP-C23MGK0M Install Microsoft Visual C++ 2015 Redistributable (x86) Succeeded
2018/10/25:22:39:19 burci LAPTOP-C23MGK0M Download Play VCREDIST2015X64 http://edutrial.autodesk.com/NET18SWDLD/2018/ACD/D7AC923A-BC24-471F-ABC1-E578C6B5D699/WI/{13EDBFB0-2...
2018/10/25:22:39:34 burci LAPTOP-C23MGK0M Download Complete VCREDIST2015X64 http://edutrial.autodesk.com/NET18SWDLD/2018/ACD/D7AC923A-BC24-471F-ABC1-E578C6B5D699/WI/{13EDBFB0-2...
2018/10/25:22:39:34 burci LAPTOP-C23MGK0M Installing Microsoft Visual C++ 2015 Redistributable (x64): "C:\Autodesk\WI\Autodesk AutoCAD 2018\3rdParty\x64\VCRedist\2015\vcredist_x64.exe" /install /quiet /norestart /log C:\Users\burci\AppData\Local\Temp\vcredist_x64_2015.log
2018/10/25:22:39:45 burci LAPTOP-C23MGK0M Microsoft Visual C++ 2015 Redistributable (x64) return code: 0
2018/10/25:22:39:45 burci LAPTOP-C23MGK0M Install Microsoft Visual C++ 2015 Redistributable (x64) Succeeded
2018/10/25:22:39:47 burci LAPTOP-C23MGK0M Download Play CADM http://edutrial.autodesk.com/NET18SWDLD/2018/ACD/D7AC923A-BC24-471F-ABC1-E578C6B5D699/WI/{13EDBFB0-2...
2018/10/25:22:40:05 burci LAPTOP-C23MGK0M Download Complete CADM http://edutrial.autodesk.com/NET18SWDLD/2018/ACD/D7AC923A-BC24-471F-ABC1-E578C6B5D699/WI/{13EDBFB0-2...
2018/10/25:22:40:05 burci LAPTOP-C23MGK0M Installing Autodesk CAD Manager Tools: INSTALLDIR="C:\Program Files\Autodesk\Autodesk CAD Manager Tools\" ADSK_EULA_STATUS=#1 MUILANG=en-us SETUP_PACKAGENAME="Autodesk® AutoCAD® 2018" SETUP_PACKAGECODE={DD42F784-12DC-49EE-8045-600335BE940B} SETUP_UNINSTALLKEYS=1 SETUP_ISLANGUAGEPACK=0 SETUP_PRODUCTDEPENDENCIES="SSE2 Support Check,Microsoft Visual C++ 2012 Redistributable (x86) Update 4,Microsoft Visual C++ 2012 Redistributable (x64) Update 4,Microsoft Visual C++ 2015 Redistributable (x86),Microsoft Visual C++ 2015 Redistributable (x64),;;;;" PACKAGEUPI={D7AC923A-BC24-471F-ABC1-E578C6B5D699} ADSK_SOURCE_ROOT="C:\Autodesk\WI\Autodesk AutoCAD 2018" INSTALLDIR="C:\Program Files\Autodesk\CAD Manager Tools\" FILESINUSETEXT="" REBOOT=ReallySuppress ADSK_SETUP_EXE=1
2018/10/25:22:40:07 burci LAPTOP-C23MGK0M Install Autodesk CAD Manager Tools Succeeded
2018/10/25:22:40:09 burci LAPTOP-C23MGK0M Download Play SUCCESSMARKER http://edutrial.autodesk.com/NET18SWDLD/2018/ACD/D7AC923A-BC24-471F-ABC1-E578C6B5D699/WI/{13EDBFB0-2...
2018/10/25:22:40:10 burci LAPTOP-C23MGK0M Download Complete SUCCESSMARKER http://edutrial.autodesk.com/NET18SWDLD/2018/ACD/D7AC923A-BC24-471F-ABC1-E578C6B5D699/WI/{13EDBFB0-2...
2018/10/25:22:40:10 burci LAPTOP-C23MGK0M PageOpen InstallCompleteDialog
2018/10/25:22:40:14 burci LAPTOP-C23MGK0M === Setup ended ===
2018/10/25:23:03:44 burci LAPTOP-C23MGK0M === Setup started on LAPTOP-C23MGK0M by burci ===
2018/10/25:23:03:44 burci LAPTOP-C23MGK0M Path_Length: 158
2018/10/25:23:03:44 burci LAPTOP-C23MGK0M Current Directory C:\Autodesk\AutoCAD_2018_English_Win_32_64bit_Trial_en-us
2018/10/25:23:03:44 burci LAPTOP-C23MGK0M Launch
2018/10/25:23:03:44 burci LAPTOP-C23MGK0M CommandLine /PK 001J1 /SN xxx-xxxxxxxx /akamai /sid SESSION_ID /skipEULA /student /url "http://edutrial.autodesk.com/NET18SWDLD/2018/ACD/D7AC923A-BC24-471F-ABC1-E578C6B5D699/WI/AutoCAD_201..."
2018/10/25:23:03:44 burci LAPTOP-C23MGK0M Current Directory C:\Users\burci\AppData\Local\Temp\_AI8626.tmp
2018/10/25:23:03:47 burci LAPTOP-C23MGK0M === Setup ended ===
2018/10/25:23:03:45 burci LAPTOP-C23MGK0M === Setup started on LAPTOP-C23MGK0M by burci ===
2018/10/25:23:03:45 burci LAPTOP-C23MGK0M Path_Length: 158
2018/10/25:23:03:45 burci LAPTOP-C23MGK0M Current Directory C:\Users\burci\AppData\Local\Temp\_AI8626.tmp
2018/10/25:23:03:45 burci LAPTOP-C23MGK0M Launch
2018/10/25:23:03:46 burci LAPTOP-C23MGK0M Download Skipped SETUPMARKER http://edutrial.autodesk.com/NET18SWDLD/2018/ACD/D7AC923A-BC24-471F-ABC1-E578C6B5D699/WI/{13EDBFB0-2...
2018/10/25:23:03:46 burci LAPTOP-C23MGK0M Download Skipped SETUP_CONFIG http://edutrial.autodesk.com/NET18SWDLD/2018/ACD/D7AC923A-BC24-471F-ABC1-E578C6B5D699/WI/{13EDBFB0-2...
2018/10/25:23:03:46 burci LAPTOP-C23MGK0M Install CustomCallback Info Invoking custom callback for details: [SETUP] CB_FUNC=CustomPlatformCheck CB_SOURCE=C:\Users\burci\AppData\Local\Temp\_AI8626.tmp\Setup\AcSetup.dll
2018/10/25:23:03:46 burci LAPTOP-C23MGK0M Install CustomCallback Info Custom callback response: Status=0 SUCCECSS Title= Message= URLTitle= URLLink=
2018/10/25:23:03:47 burci LAPTOP-C23MGK0M PageOpen LaunchDialog
2018/10/25:23:09:55 burci LAPTOP-C23MGK0M PageOpen LicenseDialog
2018/10/25:23:09:55 burci LAPTOP-C23MGK0M PageOpen ProductInfoDialog
2018/10/25:23:09:55 burci LAPTOP-C23MGK0M PageOpen ProductSelectionDialog2
2018/10/25:23:10:17 burci LAPTOP-C23MGK0M PageOpen FullProgressDialog
2018/10/25:23:10:21 burci LAPTOP-C23MGK0M Download Play STARTMARKER http://edutrial.autodesk.com/NET18SWDLD/2018/ACD/D7AC923A-BC24-471F-ABC1-E578C6B5D699/WI/{13EDBFB0-2...
2018/10/25:23:10:23 burci LAPTOP-C23MGK0M Download Complete STARTMARKER http://edutrial.autodesk.com/NET18SWDLD/2018/ACD/D7AC923A-BC24-471F-ABC1-E578C6B5D699/WI/{13EDBFB0-2...
2018/10/25:23:10:24 burci LAPTOP-C23MGK0M Download Skipped VCREDIST2008SP1X64 http://edutrial.autodesk.com/NET18SWDLD/2018/ACD/D7AC923A-BC24-471F-ABC1-E578C6B5D699/WI/{13EDBFB0-2...
2018/10/25:23:10:24 burci LAPTOP-C23MGK0M Installing Microsoft Visual C++ 2008 SP1 Redistributable (x64): "C:\Autodesk\WI\Autodesk AutoCAD 2018\3rdParty\x64\VCRedist\2008SP1\vcredist_x64.exe" /q
2018/10/25:23:10:32 burci LAPTOP-C23MGK0M Microsoft Visual C++ 2008 SP1 Redistributable (x64) return code: 1603
2018/10/25:23:10:32 burci LAPTOP-C23MGK0M Install Microsoft Visual C++ 2008 SP1 Redistributable (x64) Failed Installation aborted, Result=1603
2018/10/25:23:10:32 burci LAPTOP-C23MGK0M PageOpen InstallCompleteDialog
2018/10/25:23:11:59 burci LAPTOP-C23MGK0M === Setup ended ===
2018/10/25:23:21:54 burci LAPTOP-C23MGK0M === Setup started on LAPTOP-C23MGK0M by burci ===
2018/10/25:23:21:54 burci LAPTOP-C23MGK0M Path_Length: 158
2018/10/25:23:21:54 burci LAPTOP-C23MGK0M Current Directory C:\Autodesk\AutoCAD_2018_English_Win_32_64bit_Trial_en-us
2018/10/25:23:21:54 burci LAPTOP-C23MGK0M Launch
2018/10/25:23:21:54 burci LAPTOP-C23MGK0M CommandLine /PK 001J1 /SN xxx-xxxxxxxx /akamai /sid SESSION_ID /skipEULA /student /url "http://edutrial.autodesk.com/NET18SWDLD/2018/ACD/D7AC923A-BC24-471F-ABC1-E578C6B5D699/WI/AutoCAD_201..."
2018/10/25:23:21:54 burci LAPTOP-C23MGK0M Current Directory C:\Users\burci\AppData\Local\Temp\_AI2769.tmp
2018/10/25:23:21:57 burci LAPTOP-C23MGK0M === Setup ended ===
2018/10/25:23:21:55 burci LAPTOP-C23MGK0M === Setup started on LAPTOP-C23MGK0M by burci ===
2018/10/25:23:21:55 burci LAPTOP-C23MGK0M Path_Length: 158
2018/10/25:23:21:55 burci LAPTOP-C23MGK0M Current Directory C:\Users\burci\AppData\Local\Temp\_AI2769.tmp
2018/10/25:23:21:55 burci LAPTOP-C23MGK0M Launch
2018/10/25:23:21:56 burci LAPTOP-C23MGK0M Download Skipped SETUPMARKER http://edutrial.autodesk.com/NET18SWDLD/2018/ACD/D7AC923A-BC24-471F-ABC1-E578C6B5D699/WI/{13EDBFB0-2...
2018/10/25:23:21:57 burci LAPTOP-C23MGK0M Download Skipped SETUP_CONFIG http://edutrial.autodesk.com/NET18SWDLD/2018/ACD/D7AC923A-BC24-471F-ABC1-E578C6B5D699/WI/{13EDBFB0-2...
2018/10/25:23:21:57 burci LAPTOP-C23MGK0M Install CustomCallback Info Invoking custom callback for details: [SETUP] CB_FUNC=CustomPlatformCheck CB_SOURCE=C:\Users\burci\AppData\Local\Temp\_AI2769.tmp\Setup\AcSetup.dll
2018/10/25:23:21:57 burci LAPTOP-C23MGK0M Install CustomCallback Info Custom callback response: Status=0 SUCCECSS Title= Message= URLTitle= URLLink=
2018/10/25:23:21:57 burci LAPTOP-C23MGK0M PageOpen LaunchDialog
2018/10/25:23:22:13 burci LAPTOP-C23MGK0M PageOpen LicenseDialog
2018/10/25:23:22:13 burci LAPTOP-C23MGK0M PageOpen ProductInfoDialog
2018/10/25:23:22:13 burci LAPTOP-C23MGK0M PageOpen ProductSelectionDialog2
2018/10/25:23:22:55 burci LAPTOP-C23MGK0M PageOpen FullProgressDialog
2018/10/25:23:22:56 burci LAPTOP-C23MGK0M Download Play STARTMARKER http://edutrial.autodesk.com/NET18SWDLD/2018/ACD/D7AC923A-BC24-471F-ABC1-E578C6B5D699/WI/{13EDBFB0-2...
2018/10/25:23:22:58 burci LAPTOP-C23MGK0M Download Complete STARTMARKER http://edutrial.autodesk.com/NET18SWDLD/2018/ACD/D7AC923A-BC24-471F-ABC1-E578C6B5D699/WI/{13EDBFB0-2...
2018/10/25:23:22:58 burci LAPTOP-C23MGK0M Download Skipped VCREDIST2008SP1X64 http://edutrial.autodesk.com/NET18SWDLD/2018/ACD/D7AC923A-BC24-471F-ABC1-E578C6B5D699/WI/{13EDBFB0-2...
2018/10/25:23:22:58 burci LAPTOP-C23MGK0M Installing Microsoft Visual C++ 2008 SP1 Redistributable (x64): "C:\Autodesk\WI\Autodesk AutoCAD 2018\3rdParty\x64\VCRedist\2008SP1\vcredist_x64.exe" /q
2018/10/25:23:23:06 burci LAPTOP-C23MGK0M Microsoft Visual C++ 2008 SP1 Redistributable (x64) return code: 1603
2018/10/25:23:23:06 burci LAPTOP-C23MGK0M Install Microsoft Visual C++ 2008 SP1 Redistributable (x64) Failed Installation aborted, Result=1603
2018/10/25:23:23:06 burci LAPTOP-C23MGK0M PageOpen InstallCompleteDialog
2018/10/25:23:23:58 burci LAPTOP-C23MGK0M === Setup ended ===
2018/10/26:12:25:28 burci LAPTOP-C23MGK0M === Setup started on LAPTOP-C23MGK0M by burci ===
2018/10/26:12:25:28 burci LAPTOP-C23MGK0M Path_Length: 158
2018/10/26:12:25:28 burci LAPTOP-C23MGK0M Current Directory C:\Autodesk\AutoCAD_2018_English_Win_32_64bit_Trial_en-us
2018/10/26:12:25:28 burci LAPTOP-C23MGK0M Launch
2018/10/26:12:25:28 burci LAPTOP-C23MGK0M CommandLine /PK 001J1 /SN xxx-xxxxxxxx /akamai /sid SESSION_ID /skipEULA /student /url "http://edutrial.autodesk.com/NET18SWDLD/2018/ACD/D7AC923A-BC24-471F-ABC1-E578C6B5D699/WI/AutoCAD_201..."
2018/10/26:12:25:28 burci LAPTOP-C23MGK0M Current Directory C:\Users\burci\AppData\Local\Temp\_AI88B4.tmp
2018/10/26:12:25:31 burci LAPTOP-C23MGK0M === Setup ended ===
2018/10/26:12:25:29 burci LAPTOP-C23MGK0M === Setup started on LAPTOP-C23MGK0M by burci ===
2018/10/26:12:25:29 burci LAPTOP-C23MGK0M Path_Length: 158
2018/10/26:12:25:29 burci LAPTOP-C23MGK0M Current Directory C:\Users\burci\AppData\Local\Temp\_AI88B4.tmp
2018/10/26:12:25:29 burci LAPTOP-C23MGK0M Launch
2018/10/26:12:25:30 burci LAPTOP-C23MGK0M Download Skipped SETUPMARKER http://edutrial.autodesk.com/NET18SWDLD/2018/ACD/D7AC923A-BC24-471F-ABC1-E578C6B5D699/WI/{13EDBFB0-2...
2018/10/26:12:25:30 burci LAPTOP-C23MGK0M Download Skipped SETUP_CONFIG http://edutrial.autodesk.com/NET18SWDLD/2018/ACD/D7AC923A-BC24-471F-ABC1-E578C6B5D699/WI/{13EDBFB0-2...
2018/10/26:12:25:30 burci LAPTOP-C23MGK0M Install CustomCallback Info Invoking custom callback for details: [SETUP] CB_FUNC=CustomPlatformCheck CB_SOURCE=C:\Users\burci\AppData\Local\Temp\_AI88B4.tmp\Setup\AcSetup.dll
2018/10/26:12:25:30 burci LAPTOP-C23MGK0M Install CustomCallback Info Custom callback response: Status=0 SUCCECSS Title= Message= URLTitle= URLLink=
2018/10/26:12:25:31 burci LAPTOP-C23MGK0M PageOpen LaunchDialog
2018/10/26:12:25:47 burci LAPTOP-C23MGK0M PageOpen LicenseDialog
2018/10/26:12:25:47 burci LAPTOP-C23MGK0M PageOpen ProductInfoDialog
2018/10/26:12:25:47 burci LAPTOP-C23MGK0M PageOpen ProductSelectionDialog2
2018/10/26:12:25:50 burci LAPTOP-C23MGK0M PageOpen FullProgressDialog
2018/10/26:12:25:52 burci LAPTOP-C23MGK0M Download Play STARTMARKER http://edutrial.autodesk.com/NET18SWDLD/2018/ACD/D7AC923A-BC24-471F-ABC1-E578C6B5D699/WI/{13EDBFB0-2...
2018/10/26:12:25:53 burci LAPTOP-C23MGK0M Download Complete STARTMARKER http://edutrial.autodesk.com/NET18SWDLD/2018/ACD/D7AC923A-BC24-471F-ABC1-E578C6B5D699/WI/{13EDBFB0-2...
2018/10/26:12:25:53 burci LAPTOP-C23MGK0M Download Skipped VCREDIST2008SP1X64 http://edutrial.autodesk.com/NET18SWDLD/2018/ACD/D7AC923A-BC24-471F-ABC1-E578C6B5D699/WI/{13EDBFB0-2...
2018/10/26:12:25:53 burci LAPTOP-C23MGK0M Installing Microsoft Visual C++ 2008 SP1 Redistributable (x64): "C:\Autodesk\WI\Autodesk AutoCAD 2018\3rdParty\x64\VCRedist\2008SP1\vcredist_x64.exe" /q
2018/10/26:12:26:05 burci LAPTOP-C23MGK0M Microsoft Visual C++ 2008 SP1 Redistributable (x64) return code: 1603
2018/10/26:12:26:05 burci LAPTOP-C23MGK0M Install Microsoft Visual C++ 2008 SP1 Redistributable (x64) Failed Installation aborted, Result=1603
2018/10/26:12:26:05 burci LAPTOP-C23MGK0M PageOpen InstallCompleteDialog
2018/10/26:12:26:17 burci LAPTOP-C23MGK0M === Setup ended ===
2018/10/26:12:34:26 burci LAPTOP-C23MGK0M === Setup started on LAPTOP-C23MGK0M by burci ===
2018/10/26:12:34:26 burci LAPTOP-C23MGK0M Path_Length: 158
2018/10/26:12:34:26 burci LAPTOP-C23MGK0M Current Directory C:\Autodesk\AutoCAD_2018_English_Win_32_64bit_Trial_en-us
2018/10/26:12:34:26 burci LAPTOP-C23MGK0M Launch
2018/10/26:12:34:26 burci LAPTOP-C23MGK0M CommandLine /PK 001J1 /SN xxx-xxxxxxxx /akamai /sid SESSION_ID /skipEULA /student /url "http://edutrial.autodesk.com/NET18SWDLD/2018/ACD/D7AC923A-BC24-471F-ABC1-E578C6B5D699/WI/AutoCAD_201..."
2018/10/26:12:34:26 burci LAPTOP-C23MGK0M Current Directory C:\Users\burci\AppData\Local\Temp\_AIBC02.tmp
2018/10/26:12:34:29 burci LAPTOP-C23MGK0M === Setup ended ===
2018/10/26:12:34:27 burci LAPTOP-C23MGK0M === Setup started on LAPTOP-C23MGK0M by burci ===
2018/10/26:12:34:27 burci LAPTOP-C23MGK0M Path_Length: 158
2018/10/26:12:34:27 burci LAPTOP-C23MGK0M Current Directory C:\Users\burci\AppData\Local\Temp\_AIBC02.tmp
2018/10/26:12:34:27 burci LAPTOP-C23MGK0M Launch
2018/10/26:12:34:28 burci LAPTOP-C23MGK0M Download Skipped SETUPMARKER http://edutrial.autodesk.com/NET18SWDLD/2018/ACD/D7AC923A-BC24-471F-ABC1-E578C6B5D699/WI/{13EDBFB0-2...
2018/10/26:12:34:28 burci LAPTOP-C23MGK0M Download Skipped SETUP_CONFIG http://edutrial.autodesk.com/NET18SWDLD/2018/ACD/D7AC923A-BC24-471F-ABC1-E578C6B5D699/WI/{13EDBFB0-2...
2018/10/26:12:34:28 burci LAPTOP-C23MGK0M Install CustomCallback Info Invoking custom callback for details: [SETUP] CB_FUNC=CustomPlatformCheck CB_SOURCE=C:\Users\burci\AppData\Local\Temp\_AIBC02.tmp\Setup\AcSetup.dll
2018/10/26:12:34:28 burci LAPTOP-C23MGK0M Install CustomCallback Info Custom callback response: Status=0 SUCCECSS Title= Message= URLTitle= URLLink=
2018/10/26:12:34:29 burci LAPTOP-C23MGK0M PageOpen LaunchDialog
2018/10/26:12:34:52 burci LAPTOP-C23MGK0M PageOpen LicenseDialog
2018/10/26:12:34:52 burci LAPTOP-C23MGK0M PageOpen ProductInfoDialog
2018/10/26:12:34:52 burci LAPTOP-C23MGK0M PageOpen ProductSelectionDialog2
2018/10/26:12:35:51 burci LAPTOP-C23MGK0M PageOpen FullProgressDialog
2018/10/26:12:35:53 burci LAPTOP-C23MGK0M Download Play STARTMARKER http://edutrial.autodesk.com/NET18SWDLD/2018/ACD/D7AC923A-BC24-471F-ABC1-E578C6B5D699/WI/{13EDBFB0-2...
2018/10/26:12:35:54 burci LAPTOP-C23MGK0M Download Complete STARTMARKER http://edutrial.autodesk.com/NET18SWDLD/2018/ACD/D7AC923A-BC24-471F-ABC1-E578C6B5D699/WI/{13EDBFB0-2...
2018/10/26:12:35:55 burci LAPTOP-C23MGK0M Download Skipped VCREDIST2008SP1X64 http://edutrial.autodesk.com/NET18SWDLD/2018/ACD/D7AC923A-BC24-471F-ABC1-E578C6B5D699/WI/{13EDBFB0-2...
2018/10/26:12:35:55 burci LAPTOP-C23MGK0M Installing Microsoft Visual C++ 2008 SP1 Redistributable (x64): "C:\Autodesk\WI\Autodesk AutoCAD 2018\3rdParty\x64\VCRedist\2008SP1\vcredist_x64.exe" /q
2018/10/26:12:36:03 burci LAPTOP-C23MGK0M Microsoft Visual C++ 2008 SP1 Redistributable (x64) return code: 1603
2018/10/26:12:36:03 burci LAPTOP-C23MGK0M Install Microsoft Visual C++ 2008 SP1 Redistributable (x64) Failed Installation aborted, Result=1603
Mark.Lancaster
@Anonymous
Welcome to the Autodesk User's Community..
Your log is failing on updating Microsoft C++.  Follow this article https://knowledge.autodesk.com/support/autocad/learn-explore/caas/sfdcarticles/sfdcarticles/How-to-remove-and-reinstall-Microsoft-Visual-C-Runtime-Libraries.html
and...
There's a couple of ways to properly download and install your Autodesk product to your machine.  Please review this article and the solution it provides.
Mark Lancaster
robBouch
Hello @Anonymous
Welcome to the community!
Thank you for posting. I have translated your post for you. This is an English forum, please translate your posts for better feedback in the future.
during installation as soon as the installation is finished and no file is loaded and gives this error. Could you help?
I would suggest downloading the full installer using AVA and the Browser Download method.
I would then recommend reviewing this article for installation instructions.
If one or more of these posts helped answer your question, please click Accept as Solution on the posts that helped you so others in the community can find them easily.
robBouch
Hello @Anonymous
I'm just checking in again to see if you need more help with this. Did the suggestion I provided on Friday work for you?
If so, please click Accept as Solution on the posts that helped you so others in the community can find them easily.
