autocad 2018 material library missing
i hvae installed my autocad 2018 via online and i messed up my material library this is what i get when i try to access the material library ( see below snapshot)image.png
hoe can i reinstall my material library when i installed my autocad via online account please help anyone thanks!
Mark.Lancaster
@Anonymous
See this article https://knowledge.autodesk.com/support/autocad/learn-explore/caas/sfdcarticles/sfdcarticles/How-to-i...
Mark Lancaster
natasha.l
Hello @Anonymous,
Can you be sure you have installed AutoCAD successfully first? You will want to verify that the download & extraction went well, take a look at the size of the files.
You may also want to try the steps in this post & try another download method.  Some interference may have prevented the prerequisite libraries from installing properly.
Please "Accept Solution" if a reply or replies have helped resolve the issue or answered your question, to help others in the community.
natasha.l
Hello @Anonymous,
Just checking in with you, hope you were able to resolve this.
