Autocad 2017 Language pack not working
Message 1 of 17
I have autocad2017 Italian version installed. I have downloaded and installed the English language pack. Installation was without errors but when I start the English version, I get a fatal error and a crush. The italian version still works well.
Please find attached the errore message screenshot
Giorgio
Replies (16)
Message 2 of 17
Mark.Lancaster
@Anonymous
Welcome to the community...
A partial view of a JIT (Just-In-Time) error message is little to no use.   We would need to see the entire message.  Copy and paste it here.
Mark Lancaster
Message 3 of 17
Hi Mark,
thank you.
The error message is quite long:
Application does not support just-in-time (JIT)
debugging. See the end of this message for details.
************** Exception Text **************
System.Windows.Markup.XamlParseException: Set connectionId threw an exception. ---> System.InvalidCastException: Unable to cast object of type 'System.Windows.Controls.Grid' to type 'System.Windows.Controls.ContextMenu'.
at Autodesk.AutoCAD.UserControls.DocumentSwitchControl.System.Windows.Markup.IComponentConnector.Connect(Int32 connectionId, Object target)
at MS.Internal.Xaml.Runtime.ClrObjectRuntime.SetConnectionId(Object root, Int32 connectionId, Object instance)
--- End of inner exception stack trace ---
at System.Windows.Markup.XamlReader.RewrapException(Exception e, IXamlLineInfo lineInfo, Uri baseUri)
at System.Windows.Markup.WpfXamlLoader.Load(XamlReader xamlReader, IXamlObjectWriterFactory writerFactory, Boolean skipJournaledProperties, Object rootObject, XamlObjectWriterSettings settings, Uri baseUri)
at System.Windows.Markup.WpfXamlLoader.LoadBaml(XamlReader xamlReader, Boolean skipJournaledProperties, Object rootObject, XamlAccessLevel accessLevel, Uri baseUri)
at System.Windows.Markup.XamlReader.LoadBaml(Stream stream, ParserContext parserContext, Object parent, Boolean closeStream)
at Autodesk.AutoCAD.ViewModel.DocumentSwitch.DocumentSwitchServices.CreateDocumentSwitchControl()
at Autodesk.AutoCAD.ViewModel.DocumentSwitch.DocumentSwitchServices.GetInstance()
at Autodesk.AutoCAD.ViewModel.DocumentSwitch.DocumentSwitchServices.PlaceDocumentSwitchControl()
at Autodesk.AutoCAD.Runtime.CommandClass.InvokeWorker(MethodInfo mi, Object commandObject, Boolean bLispFunction)
at Autodesk.AutoCAD.Runtime.CommandClass.InvokeWorkerWithExceptionFilter(MethodInfo mi, Object commandObject, Boolean bLispFunction)
at Autodesk.AutoCAD.Runtime.CommandClass.CommandThunk.Invoke()
************** Loaded Assemblies **************
mscorlib
Assembly Version: 4.0.0.0
Win32 Version: 4.6.1086.0 built by: NETFXREL4STAGE
CodeBase: file:///C:/Windows/Microsoft.NET/Framework64/v4.0.30319/mscorlib.dll
Acdbmgd
Assembly Version: 21.0.0.0
Win32 Version: 21.0.301.0.0
CodeBase: file:///C:/Program%20Files/Autodesk/AutoCAD%202017/AcdbMgd.DLL
adui21
Assembly Version: 0.0.0.0
CodeBase: file:///C:/Program%20Files/Autodesk/AutoCAD%202017/adui21.DLL
AdUiPalettes
CodeBase: file:///C:/Program%20Files/Autodesk/AutoCAD%202017/AdUiPalettes.DLL
WindowsBase
CodeBase: file:///C:/windows/Microsoft.Net/assembly/GAC_MSIL/WindowsBase/v4.0_4.0.0.0__31bf3856ad364e35/WindowsBase.dll
System.Core
CodeBase: file:///C:/windows/Microsoft.Net/assembly/GAC_MSIL/System.Core/v4.0_4.0.0.0__b77a5c561934e089/System.Core.dll
System
CodeBase: file:///C:/windows/Microsoft.Net/assembly/GAC_MSIL/System/v4.0_4.0.0.0__b77a5c561934e089/System.dll
PresentationFramework
CodeBase: file:///C:/windows/Microsoft.Net/assembly/GAC_MSIL/PresentationFramework/v4.0_4.0.0.0__31bf3856ad364e35/PresentationFramework.dll
PresentationCore
CodeBase: file:///C:/windows/Microsoft.Net/assembly/GAC_64/PresentationCore/v4.0_4.0.0.0__31bf3856ad364e35/PresentationCore.dll
System.Xaml
CodeBase: file:///C:/windows/Microsoft.Net/assembly/GAC_MSIL/System.Xaml/v4.0_4.0.0.0__b77a5c561934e089/System.Xaml.dll
AdApplicationFrame
Win32 Version: 2015.11.2.0
CodeBase: file:///C:/Program%20Files/Autodesk/AutoCAD%202017/AdApplicationFrame.DLL
AdWindows
Assembly Version: 2016.5.0.0
Win32 Version: 2016.5.0.0
CodeBase: file:///C:/Program%20Files/Autodesk/AutoCAD%202017/AdWindows.DLL
System.Configuration
CodeBase: file:///C:/windows/Microsoft.Net/assembly/GAC_MSIL/System.Configuration/v4.0_4.0.0.0__b03f5f7f11d50a3a/System.Configuration.dll
System.Xml
CodeBase: file:///C:/windows/Microsoft.Net/assembly/GAC_MSIL/System.Xml/v4.0_4.0.0.0__b77a5c561934e089/System.Xml.dll
WindowsFormsIntegration
CodeBase: file:///C:/windows/Microsoft.Net/assembly/GAC_MSIL/WindowsFormsIntegration/v4.0_4.0.0.0__31bf3856ad364e35/WindowsFormsIntegration.dll
PresentationFramework.Aero
CodeBase: file:///C:/windows/Microsoft.Net/assembly/GAC_MSIL/PresentationFramework.Aero/v4.0_4.0.0.0__31bf3856ad364e35/PresentationFramework.Aero.dll
System.Drawing
CodeBase: file:///C:/windows/Microsoft.Net/assembly/GAC_MSIL/System.Drawing/v4.0_4.0.0.0__b03f5f7f11d50a3a/System.Drawing.dll
accoremgd
CodeBase: file:///C:/Program%20Files/Autodesk/AutoCAD%202017/accoremgd.DLL
Acmgd
CodeBase: file:///C:/Program%20Files/Autodesk/AutoCAD%202017/Acmgd.DLL
AcWindows
CodeBase: file:///C:/Program%20Files/Autodesk/AutoCAD%202017/AcWindows.DLL
AcWindows.resources
Win32 Version: 21.0.52.0.0
CodeBase: file:///C:/Program%20Files/Autodesk/AutoCAD%202017/en-US/AcWindows.resources.DLL
AcCui
CodeBase: file:///C:/Program%20Files/Autodesk/AutoCAD%202017/AcCui.DLL
PresentationFramework-SystemXml
CodeBase: file:///C:/windows/Microsoft.Net/assembly/GAC_MSIL/PresentationFramework-SystemXml/v4.0_4.0.0.0__b77a5c561934e089/PresentationFramework-SystemXml.dll
PresentationUI
CodeBase: file:///C:/windows/Microsoft.Net/assembly/GAC_MSIL/PresentationUI/v4.0_4.0.0.0__31bf3856ad364e35/PresentationUI.dll
System.Xml.Linq
CodeBase: file:///C:/windows/Microsoft.Net/assembly/GAC_MSIL/System.Xml.Linq/v4.0_4.0.0.0__b77a5c561934e089/System.Xml.Linq.dll
System.Windows.Forms
CodeBase: file:///C:/windows/Microsoft.Net/assembly/GAC_MSIL/System.Windows.Forms/v4.0_4.0.0.0__b77a5c561934e089/System.Windows.Forms.dll
PresentationFramework-SystemXmlLinq
CodeBase: file:///C:/windows/Microsoft.Net/assembly/GAC_MSIL/PresentationFramework-SystemXmlLinq/v4.0_4.0.0.0__b77a5c561934e089/PresentationFramework-SystemXmlLinq.dll
AcSeamless
CodeBase: file:///C:/Program%20Files/Autodesk/AutoCAD%202017/AcSeamless.DLL
Microsoft.GeneratedCode
Assembly Version: 1.0.0.0
AcSeamless.resources
CodeBase: file:///C:/Program%20Files/Autodesk/AutoCAD%202017/en-US/AcSeamless.resources.DLL
BIM360GlueAutoCAD2017Addin
Assembly Version: 4.37.6853.0
Win32 Version: 4.37.6853.0
CodeBase: file:///C:/ProgramData/Autodesk/ApplicationPlugins/AutoCAD2017Addin.bundle/Contents/Win64/BIM360GlueAutoCAD2017Addin.dll
BIM360GlueAddinsCommon
CodeBase: file:///C:/ProgramData/Autodesk/ApplicationPlugins/AutoCAD2017Addin.bundle/Contents/Win64/BIM360GlueAddinsCommon.DLL
log4net
Assembly Version: 1.2.11.0
Win32 Version: 1.2.11.0
CodeBase: file:///C:/ProgramData/Autodesk/ApplicationPlugins/AutoCAD2017Addin.bundle/Contents/Win64/log4net.DLL
FeaturedAppsPlugin
Win32 Version: 21.0.46.0.0
CodeBase: file:///C:/Program%20Files%20(x86)/Autodesk/ApplicationPlugins/Autodesk%20FeaturedApps.bundle/Contents/Windows/2017/Win64/FeaturedAppsPlugin.dll
ContextualTabSelectorRules
CodeBase: file:///C:/Program%20Files/Autodesk/AutoCAD%202017/AcWindows.dll
Microsoft.Expression.Interactions
Win32 Version: 2.0.20520.0
CodeBase: file:///C:/Program%20Files/Autodesk/AutoCAD%202017/Microsoft.Expression.Interactions.DLL
************** JIT Debugging **************
Application does not support Windows Forms just-in-time (JIT)
debugging. Contact the application author for more
information.
Then I click on continue and I get the fatal error (see attached screenshot)
Message 4 of 17
Mark.Lancaster
@Anonymous
It appears you may have a netframe issue but I will tag @Darin.Green and @TravisNave for their input as well.
Mark Lancaster
Message 5 of 17
Ivan.Treguear
Hello @Anonymous
You can try to perform a clean uninstall of your product and also to the language pack that you have installed. The Microsoft Fixit tool can be used to uninstall them. Please let us know if the information allowed you to resolve your request.
Message 6 of 17
natasha.l
Hello @Anonymous,
Thank you for posting to the forum.
This error may indicate that the video card is not powerful enough to support the application.
Please refer to this link for more information:
http://upandready.typepad.com/up_and_ready/2011/09/autocad-family-jit-just-in-time-debugging-errors....
I hope this answered your question or resolved the issue, if so please click Kudos or the "thumbs-up!" Did my response help resolve the issue? Please "Accept As Solution" to help others in the community.
Message 7 of 17
@Mark.Lancaster
so..what if it's a netframe issue? what should I do?
Message 8 of 17
@Ivan.Treguear
do you mean that I should unistall all the suite? Or just Autocad? That would require a lot of time, I'll try if there's no better solution
Message 9 of 17
@natasha.l
how is it possible that my video card is powerful enough to run Autocad in Italian but not in English??
Message 10 of 17
Alexander.Rivilis
@Anonymous
You can check if error related to video if disable video acceleration: https://knowledge.autodesk.com/support/autocad/troubleshooting/caas/sfdcarticles/sfdcarticles/Starti...
Are all AutoCAD ServicePacks, Updates, HotFixes installed on your system?
Your error is very similar for this: http://forums.autodesk.com/t5/installation-licensing/autocad-2017-1-update-fatal-error/td-p/6679969
Відповідь корисна? Клікніть на "ВПОДОБАЙКУ" цім повідомленням! | Do you find the posts helpful? "LIKE" these posts!
Находите сообщения полезными? Поставьте "НРАВИТСЯ" этим сообщениям!
На ваше запитання відповіли? Натисніть кнопку "ПРИЙНЯТИ РІШЕННЯ" | Have your question been answered successfully? Click "ACCEPT SOLUTION" button.
На ваш вопрос успешно ответили? Нажмите кнопку "УТВЕРДИТЬ РЕШЕНИЕ"
Alexander Rivilis / Александр Ривилис / Олександр Рівіліс
Programmer & Teacher & Helper / Программист - Учитель - Помощник / Програміст - вчитель - помічник
Facebook | Twitter | LinkedIn
Expert Elite Member
Message 11 of 17
It's not a video related issue. All the hotfix /service pack are installed.
Message 12 of 17
Ivan.Treguear
Hi @giorgio.sciandra,
I would like to know if you have tried the possible solutions provided. Please let us know if you need more assistance.
Message 13 of 17
Hi @Ivan.Treguear
after a clean uninstall and a reinstallation, it works!
Thank you.
Message 14 of 17
Lurifax
answered a similar question here
http://forums.autodesk.com/t5/installation-licensing/autocad-2017-1-update-fatal-error/m-p/6868558#M...
If you install the language pack separately with a command similar to this (you can add paths, logging, silent etc.)
msiexec /p "acadLP_ENU.msp" REINSTALLMODE="ecmus" REINSTALL="ALL"
Message 15 of 17
freesbee
AutoCAD 2017 Unhandled Access Violation Reading 0x0008 Exception at 9ff4bcah
[SYMPTOMS]
When installing a language pack on top of an AutoCAD verticalization (Mechanical, Architectural...) already with an update, and you try to start the product of Language Packed version, AutoCAD first gives an error like this one:
 and then crashes with an error similar to this one:AutoCAD_ERR02.PNG
while the core language still works fine (for "core language" I mean the language of the initial installation).
[FIX]
It appears to be a known issue, but I haven't found any reference to the specific error, so I'm writing it here and maybe other users will save time.
You don't need to reinstall AutoCAD (that's the long solution for people with a lot of time and not many installations to manage).
The issue gets solved if the update is reinstalled after installing the Language Pack.
I am not talking about the "AutoCAD 2017 Service Pack 1". The right update to reinstall is the
AutoCAD 2017 Service Pack 1.1
that can be downloaded via subscription account (about 450 MBytes file).
After that action also the AutoCAD and its verticalizations will work properly even in the language pack version.
Of course, if you install multiple language packs, then install the update after the last one.
Hope it helps Smiley Wink
(I posted the same answer in the other post)
Massimo Frison
CAD R&D // PDM Admin · Hekuma GmbH
Message 16 of 17
m_latz
Reinstall is not necessary, just a repair.
This problem was solved some time ago:
https://forums.autodesk.com/t5/installation-lizenzierung/autocad-2017-deutsches-sprachpacket-fehler/...
regards
Markus
Message 17 of 17
freesbee
of course reinstall or repair does technically the same (the installer actually offers a button with "Repair" instead of "Install").
But I imagine that Giorgio Sciandra did not come to the idea of searching for the problem in German language, so I posted it here as well. I had myself the same problem with EN-FR localization and EN-RU localization, and since I don't have enough time to post it in each language, I posted it here.
Maybe I'll be able to collect a kudo with this Smiley Wink
Massimo Frison
