AutoCAD 2017 imaging on Windows 10
jleavitt
Message 1 of 9
jleavitt
I have created a deployment for AutoCAD Map 3D 2017 and Raster Design 2017 using a newly imaged Windows 10 computer.  The deployment runs properly and the programs are installed, but when I try to start the program I can't get past the initialization screen.  I've let it run for up to 3 hours with no progress.
The deployment installs the products and they run properly on our existing Windows 7 machines so it appears that there's a problem with AutoCAD running on Windows 10.  Are there any known issues with this configuration?
Thank You,
J Leavitt, PLS
Land Surveyor
Bureau of Land Management
California State Office
Replies (8)
Message 2 of 9
Otto
Hello jleavitt
It looks like you are experiencing issues with your product on Windows 10 or want to know which Autodesk products are supported on Windows 10. Community members with similar questions found the following article(s) useful:
Windows 10 support for Autodesk products
Other threads about Windows 10 support
Change your mind about Windows 10? Here's how you can roll back
Please consider bookmarking these pages and checking back often; we'll update with new information as our testing continues.
If this information was helpful, please consider marking it as an Accepted Solution by clicking on the "Accept as Solution" link, below. Taking a moment to do this will help others with similar questions find useful answers. Thank you!
Kudos (click on the link or the "thumbs-up!" icon), are also gratefully received! (Even a bot likes praise.)
If this answer missed the mark, please let us know so that other community members can lend a hand. Any additional details might help, too: consider including relevant screenshots, log files, error messages, or system specs.
I'm a software-based HelpBot, designed to provide the information you need to get up and running with Autodesk products—any time, day or night. Your feedback will help train me to deliver more accurate and helpful answers. Thanks in advance! Also, please note that I'm only set up to respond to the first post of a topic, not to any replies. Thank you!
Helpful links: Find Serial Numbers and Product Keys | Find Downloads and Service Packs | Activate Autodesk software
Message 3 of 9
jleavitt
What I gather from the links in your reply is that AutoCAD 2017 products will not work on the Windows 10 platform because of their reliance on .NET FRAMEWORK 4.6.  Normally I would accept that explanation, but I undertook to install that product on my Windows 10 computer only to be informed that .NET FRAMEWORK 4.6 was already installed on the system.
So, who do I believe Microsoft or AutoDesk?
You guys need to get on the same page...Quickly.
J Leavitt, PLS
Land Surveyor
Message 4 of 9
natasha.l
Hello @jleavitt,
Sorry to hear you are encountering issue with imaging software. My thought is that maybe the computer may not be identical to the original computer that the image was created on. The Windows registry settings and installed drivers for the master computer will be duplicated to every other computer.  If you restore an image to a computer with a different hardware configuration, you will have incompatibility issues which may or may not be solvable.
Please review the Imaging Software
Thank you for posting! Smiley Happy
Message 5 of 9
natasha.l
Hello @jleavitt,
Have you tried installing the software directly from the install files Setup.exe?
If it works, the deployment may have been the issue. If not then it would indicate there is an issue on that machine.
Please report back on your progress. Smiley Happy
Message 6 of 9
jleavitt
Thank you for your reply.
It appears that the absence of an application named .NET FRAMEWORK 4.6,
which cannot be installed on Windows 10 systems. I tried to install it
manually and was informed that it was already on the computer. Apparently,
the functionality of .NET 4.6 is included in the Windows 10 operating
system and AutoDesk doesn't know how to access it.
J Edward Leavitt
Land Surveyor
Land, Title & Survey Mapping Section
DOI/BLM-CA State Office
2800 Cottage Way W-1939
Sacramento, CA 95825-1886
[email protected]
916.978.4347
J Leavitt, PLS
Land Surveyor
Message 7 of 9
Mark.Lancaster
@jleavitt
I can read your posting 2 ways so I want to confirm what you're experiencing..
1.  Is the issue.. Hanging when you are trying to install the software using the deployment on Windows 10?
2.  Is the issue based on you launching the application after the deployment has installed the software and finished?
"Hanging on initializing" usually means its hung while the software is being installed...  Smiley Very Happy  So that's why I'm a little confused..
Or does it mean the splash screen is hung and you need to look at the solutions here: https://knowledge.autodesk.com/support/autocad/troubleshooting/caas/sfdcarticles/sfdcarticles/Softwa...
Mark Lancaster
Message 8 of 9
jleavitt
Thanks for your reply.
It's hanging while launching the application. I've isolated it to the fact
that .NET 4.6 cannot be installed on Windows 10 systems, but AutoCAD 2017
relies on it.
J Edward Leavitt
Land Surveyor
[email protected]
916.978.4347
J Leavitt, PLS
Land Surveyor
Message 9 of 9
Darin.Green
@jleavitt,
That's not correct. .Net Framework is apart of the Windows 10 install. That being said, make sure you have the .NET Framework 4.6 Advanced Services enabled in Programs & Features > Turn Windows features on or off
If this information was helpful, please consider using the Accept Solution
