Autocad 2016 keeps forever loading
Could someone please help me ? I've been struggling with this for a while and I'm desperate.
My autocad just keeps loading, forever and ever. I have tried repair, reinstall and complete uninstall/install with no success.
There's no problem with my licence and there's enough space on the computer to operate this. So what could be the problem and what can I do ? Thank you in advance for your response
Darin.Green
@Anonymous
When you first launch the application after an install, you're asked to choose a licensing type to use. That being the case, there may be a window open behind the loading screen. You should also change your resolution to a higher value then launch the application again.
If that doesn't work, use Alt+Space Bar to bring the current windows to the forefront.
If this information was helpful, please consider using the Accept Solution
