Announcements
AutoCAD 2014 LT The serial number you entered is not valid. Try again. (1)
Message 1 of 9
I've installed AutoCAD 2014 LT on a new load on my new laptop.  i get the error:
when i attempt to activate it.
After hours of web searches, editing the registry to try a network install, …  I'm no closer to using the product.  I've tried e-mailing through the contact us page.
What have i done wrong here?  any help would be greatly appreciated.
Replies (8)
Message 2 of 9
leowarren34
What OS is this?
Is this a physical copy?
If you want to contact autodesk support go here: https://knowledge.autodesk.com/contact-support/installation-activation
Leo Warren
Autodesk Student Ambassador Diamond
Please accept as solution and give likes if applicable.
Message 3 of 9
Mark.Lancaster
@Anonymous
Usually this means your given serial # is invalid or not active anymore due to the history of your product.   Meaning it may have been on existing maintenance plan that's no longer valid, you traded it in for a newer version.   But we are only users here and have no clue about the history of this serial #.
Mark Lancaster
Message 4 of 9
Thanks for the reply. We bought a 5 seat license. We are formatting and
loading Windows 10 on our computers. The first load is my computer and I
just loaded AutoCAD 2014 the normal way, entered the normal serial number
and I got that message when I tried to activate. What kills me is no reply
at all from Autodesk when I went through the contact channel the website
told me to go through. Thanks again.
Message 5 of 9
Thank you for the reply. The OS is Windows 10. It’s a physical copy, yes.
The link to help only goes back to AutoCAD 2016 LT. Our version is AutoCAD 2014 LT (we have a 5 license copy). Still, I submitted a request for help through that link a few weeks ago and I’ve gotten no reply.
Thanks again
Message 6 of 9
leowarren34
I would keep contacting them until you get a reponse, you eventually will.
Leo Warren
Message 7 of 9
Do you know for sure that you still have a valid entitlement for this version? I.e. are your licenses perpetual licenses or perpetuals with an active maintenance plan or have you switched to subscription?
Edit: Also, 2014 is not supported on Windows 10 so it might not work properly or at all.
Message 8 of 9
Hi - thanks for the response. We bought a 5 seat pack of permanent
licenses. I ran it in Windows 10 for more than a year with no issue. When
it came time to reload, I got the error message. Still no reply from
Autodesk.
Message 9 of 9
leowarren34
Windows 10 will likely throw problems, however activation support will be able to get you new codes should you need them.
Leo Warren
