Are these specs good for vray 3ds max rendering??
hello all
my question is are these specs good for 3ds max 3d rendering??
HP PREMIUM SERIES
ENVY 17T
4TH GENERATION CORE I7 4700
16GB DDR3 RAM
750GB HDD
GT740 2GB DEDICATED UP TO 5GB
HD 1600X900 LED SCREEN
darawork
Specs seem ok, although I personally wouldn't use a laptop for rendering. They get too hot and die before long. Depends on what you are using it for though; 24/7 straight number crunching torture or a quick few pictures for college?
Darawork
AutoDesk User
Windows 10/11, 3DS Max 2022/24, Revit 2022, AutoCad 2024, Dell Precision 5810/20, ASUS DIY, nVidia Quadro P5000/RTX 5000/GTX760
hello, thank you for replying
I am an engineer student and i want to use this laptop for my final project..
i know desktops are better for renderings but i have no choice
i have another choice with Toshiba Qosmio
Qosmio specs:
core i7
16gb ram
1tb Hdd
vga: gtx 670 3gb ddr5
are thse specs good for rendering??
thank you
Steve_Curley
Depends on which renderer you intend to use. Scanline/Mental Ray/Vray do not use the graphics card for rendering. Iray/Quicksilver/VrayRT do.
The GTX is a consumer card. While it will (probably) work it is not made to withstand 100% usage for hour after hour of rendering. For that kind of work you really need a workstation quality card (Quadro).
For normal Vray the Toshiba looks a better machine, but watch out for overheating problems with long renders (most laptops seem to suffer from it).
Max 2016 (SP1/EXT1)
Win7Pro x64 (SP1). i5-3570K @ 4.4GHz, 8Gb Ram, DX11.
nVidia GTX760 (2GB) (Driver 430.86).
darawork
Here is a list of 'top 10 workstation laptops' fwiw; http://www.notebookcheck.net/Top-10-Workstation-Laptops.65537.0.html
Darawork
AutoDesk User
Thank you guys this is really helpful
eodeo
As long as your cooling is good (non laptop) GTX or radeon cards will render just fine. With that said, they are not desinged to render 24/7 and may die, but that's what warranty is for. Most GPUs come with at least 3year warranty- and that gives you plenty of time before the cards get obsolete and you want to get the new ones anyway.
