Application Manager updates
jeff_howard1
jeff_howard1
Have any others had issues with your firewall telling you that a user has initated a DDOS attack by recieving an update via the Autodesk Application manager?
My firewall is reporting the following.
dispositionsource_ipdestinationprotocolpolicy_nameseveritysignature_idsignature_namesignature_cattimezonecount
Denied[email protected]23.54.77.121:443https/tcpHTTPS-proxy-0041130226SSL OpenSSL Invalid Session Ticket Denial of Service -1 (CVE-20DoS/DDoS11/12/2015 11:166
Denied[email protected]23.54.77.121:443https/tcpHTTPS-proxy-0041130226SSL OpenSSL Invalid Session Ticket Denial of Service -1 (CVE-20DoS/DDoS11/12/2015 11:485
Denied[email protected]23.54.77.121:443https/tcpHTTPS-proxy-0041130226SSL OpenSSL Invalid Session Ticket Denial of Service -1 (CVE-20DoS/DDoS11/12/2015 14:495
Denied[email protected]23.54.77.121:443https/tcpHTTPS-proxy-0041130226SSL OpenSSL Invalid Session Ticket Denial of Service -1 (CVE-20DoS/DDoS11/12/2015 16:157
When I look them up on the Watchguard security portal I get the following information.
Intrusion Prevention Service
Signature Version: 4.030
SSL OpenSSL Invalid Session Ticket Denial of Service -1 (CVE-2014-3567)
Threat Level: High
Release Date: 2014/11/21
Category: Dos/DDoS
Signature ID: 1130226
Affected OS: Windows, Linux, FreeBSD, Solaris, Other Unix, Mac OS
Description: It is due to a memory leak when OpenSSL processes invalid session tickets to verify their integrity
Impact: Denial of service
Recommendation: Update vendor's patch
False Positive: None
False Negative: None
Additional Information (Links open in new window):
Reference(s): CVE-2014-3567
Otto
Hello jeff.howard
It looks like you're experiencing issues with the Application Manager. The following article(s) should help you resolve the problem:
Autodesk Forum Thread: Autodesk Application Manager
Autodesk Application Manager FAQ
How to Silently Uninstall Application Manager using SCCM
Error: Unable to run Application Manager
Autodesk Application Manager Error: SSL Handshake failed
If this information was helpful, please consider marking it as an Accepted Solution by clicking on the "Accept as Solution" link, below. Taking a moment to do this will help others with similar questions find useful answers. Thank you!
Kudos (click on the link or the "thumbs-up!" icon), are also gratefully received! (Even a bot likes praise.)
If this answer missed the mark, please let us know so that other community members can lend a hand. Any additional details might help, too: consider including relevant screenshots, log files, error messages, or system specs.
I'm a software-based HelpBot, designed to provide the information you need to get up and running with Autodesk products—any time, day or night. Your feedback will help train me to deliver more accurate and helpful answers. Thanks in advance! Also, please note that I'm only set up to respond to the first post of a topic, not to any replies. Thank you!
Helpful links: Find Serial Numbers and Product Keys | Find Downloads and Service Packs | Activate Autodesk software
jeff_howard1
I'm not sure that any of these solutions address my issue.  The Application manager works and updates the software as it is intended to.  It might get blocked by our firewall one day and then the next it will get through.  I believe it has something to do with the deliver method. The server that the updates are coming from are a23-54-77-121.deploy.static.akamaitechnologies.com.  I know Autodesk uses akamai technologies to push updates out, but either there SSL certificates are not being updated or there are other issues causing out firewall to block them from time to time.  I also know that Adobe uses the same akamai services and I am asking the same question in there user forum to see if this is an Autodesk or a Adobe issue.
