AdskLicensing-installer won't run trying to fix License Error - ADLSDK_STATUS_AUTH_PENDING
rramirez19ZZZF
Observer Observer
rramirez19ZZZF
Observer
Observer
AdskLicensing-installer won't run. I am trying to fix License Error - ADLSDK_STATUS_AUTH_PENDING
I am using AutoCad 2022 on a new computer brand new install. not long after i start the program i see the
ADLSDK_STATUS_AUTH_PENDING error. I can see that the autodesk licensing service is stopped and won't start. I found an article that suggests updating the Autodesk Desktop Licensing Service. so i downloaded using AKN. When i try to run the extracted exe it never opens.
What is causing this? I already put a check to unblock the exe from running, what else can I try?
thanks B
gary.bushVNXH2
Community Visitor
Community Visitor
I have same issue were you able to sort it out?
rramirez19ZZZF
Observer
Observer
Yes this is the solution
CHECK IF THE SERVICE IS RUNNING, IT IS CALLED “Autodesk Desktop Licensing Service” if it is stopped try to start it. If it won’t start you will have to reinstall the service.
details in the attachment
gustipalobo11
Community Visitor
Community Visitor
aplikasi AdsklicensingInstall 9.2.2.2501 tidak bisa terbuka
gustipalobo11
Community Visitor
Community Visitor
mohon bantuannya
yudho.bagus
Hi @rramirez19ZZZF,
Can you send a screenshot of the error message?
yudho.bagus
Hi @gustipalobo11,
Sudah coba uninstall Autodesk Desktop Licensing Service dari control panel, lalu instal kembali Autodesk Desktop Licensing Service.
