Activation of inventor using build proxy function in Windows 10
I´m trying to setup activation through the proxy method, but I can´t get it working. I have tried following this article, but still no luck: https://knowledge.autodesk.com/search-result/caas/sfdcarticles/sfdcarticles/Meta-licensing.html It´s like the list of sites need for activtion through the proxy method is in complete, all I get is that it cannot establish a connection to the internet. Can someone help to try and resolve this problem?
natasha.l
Hello @Anonymous,
I have listed some common solutions for this problem below:
  1. Apply the TLS Licensing Updates from our site, this update is required for some products
  2. Use a Windows Administrator profile
  3. Connection issues Adjust Lan Settings, Proxy Settings & etc. , or try a different network location
  4. Sign-out of all Autodesk related products. Please try the following, How to sign out of the Autodesk Desktop app
  5. Be sure to sign-in with the proper Autodesk ID & Password, resetting and Changing Your Autodesk Account Password
  6. Temporarily disable security settings like Antivirus, Firewall & UAC on your Windows operating system
  7. If you are using HTTP Inspection to unencrypt traffic you may need to generate the root certiciate
  8. Use Fiddler to locate web sessions being processed on the system, to locate network traffic
  9. Whitelist the sites listed in these articles:
What URLs/Protocols Are Accessible for Subscription Licenses
Subscription Licensing Error: "Establish an Internet connection to continue"
Please "Accept Solution" if a reply or replies have helped resolve the issue or answered your question, to help others in the community.
