Activation code
Activation code
Activation code
 I have AutoCad Mechanical 2012. I need Activation code for it.Serial number is:- 362-12868261
Name of person:- Nilesh Ingle
E-mail address:- nilesh@warade.in
Company name:-Warade Automation Solution Pvt. Ltd.
Company address:-nanded village, pune, maharashtra, India
Serial number:- 362-12868261
Otto
Hello warade and welcome to the Autodesk community!
It looks like you need help Finding an Activation Code. Community members with similar questions found the following article(s) useful:
Manually Activating Your Autodesk Software
If this information was helpful, please consider marking it as an Accepted Solution by clicking on the "Accept as Solution" link, below. Taking a moment to do this will help others with similar questions find useful answers. Thank you!
Kudos (click on the link or the "thumbs-up!" icon), are also gratefully received! (Even a bot likes praise.)
If this answer missed the mark, please let us know so that other community members can lend a hand. Any additional details might help, too: consider including relevant screenshots, log files, error messages, or system specs.
I'm a software-based HelpBot, designed to provide the information you need to get up and running with Autodesk products—any time, day or night. Your feedback will help train me to deliver more accurate and helpful answers. Thanks in advance! Also, please note that I'm only set up to respond to the first post of a topic, not to any replies. Thank you!
Helpful links: Find Serial Numbers and Product Keys | Find Downloads and Service Packs | Activate Autodesk software
Darin.Green
Please remove your serial number information from the post. Remember this is a publicly open forum.
In regards to the issue you're having, you should reach out to your reseller. I think the contract associated with that serial number expired and the last version before expiration was newer then 2012.
Your reseller or Autodesk will be able to clear this up for you.
If this information was helpful, please consider using the Accept Solution
please delete this post
