Activation code not responding for Autocad 2017
After reinstalling AutoCAD 2017 I tried using my activation code I got the last time, and it doesn't like it. Please advise on how to activate the software.
Mark.Lancaster
@Anonymous
First may I ask why you are responding to an activation code issue for 2007 when your product is 10 years newer?  Please create your own posting and not hi-jack others..  Smiley Wink
Now to your problem..  What message are you seeing?   Share a screen shot but blur all sensitive information.  Are you a student or do you have a commercial license?
Mark Lancaster
natasha.l
Hello @Anonymous,
You shouldn't need to activate manually with an activation code this is for offline activation, an offline activation is the last resort.
Please try to review the information below:
How to activate Educational Software
  1. Review the Steps for Setting-Up Student Software depending on the download method it will automatically recognize your credentials & sign-in or you manually type in the serial# & product key (you shouldn't need an activation code)
  2. Temporarily disable security settings like Antivirus, Firewall & UAC on your Windows operating system
  3. An internet connection is required to activate, every 30days you should be connected to the internet at some point (to verify your license & use the software) Adjust your proxy settings, to allow access during the install & first launch, also make sure you have an uninterrupted connection. You can try another Wifi network location
  4. If the online method does not work & you need a activate code for offline activation, fill out this form with the educational support team or use Register.autodesk.com
Keep us posted.
Please "Accept As Solution" if a reply or replies have helped resolve the issue or answered your question, to help others in the community.
natasha.l
Hello @Anonymous,
Just checking in with you, hope you were able to resolve this, & activate your software.
Thank you for posting, please "Accept As Solution" if a reply or replies have helped resolve the issue or answered your question, to help others in the community.
