Accidentally uninstalled Desktop Licensing Service - How to restore?
I was cleaning up my PC and accidentally uninstalled the Desktop Licensing Service (5.1.4).
Now none of my Design Suite programs work as they can't do a license check (Autocad, 3ds Max).
I don't really want to wipe everything and start again --- is there a way of just reinstalling the Desktop Licensing Service (5.1.4) [2018]?
Thanks.
Mark.Lancaster
@Anonymous
For 2018 you actually need 5.1.5..   Or this https://knowledge.autodesk.com/search-result/caas/sfdcarticles/sfdcarticles/Autodesk-License-Service...
Mark Lancaster
Thanks...but how do I get it! The link takes me to a hotfix, which requires the Service to be already installed!
Search for CLIC_x86_Release.msi and/or CLIC_x64_Release.msi in your downloaded source files for your product, e g  C:\Autodesk\Autodesk_3ds_Max_2018_EFGJKPS_Win_64bit_dlm\x64\CLIC\CLIC_x64_Release.msi
Utter freakin' genius.
Thank you! Just applied the Hot Fix to take 5.1.4 to 5.1.5 purrrfect....
How the heck did you figure that out?
Open the source column in add/remove programs:
