acad.exe - System Error
Message 1 of 14
I would like to point out that during autocad installation, there was no problem. so why can not I start the program?
Replies (13)
Message 2 of 14
-FDC-
What windows are you running ?
Message 3 of 14
windows 7 64 - Autocad 2018
Message 4 of 14
imadHabash
i suggest to check this article that may help you . >> Click <<
Imad Habash
Message 5 of 14
thank you very much, I had already read it, but only after I wrote this post. tomorrow I try and let you know
Message 6 of 14
-FDC-
Message 7 of 14
what is it and what is it for?
Message 8 of 14
-FDC-
To check if you are using all the latest updates.
Message 9 of 14
yes, I installed it. what does this have to do with my problem?
Message 10 of 14
I could not install windows 10 sdk kit because:
d3dcompiler_43.dll is missing
what a bad luck! what kind of problem does my pc have?
Message 11 of 14
natasha.l
Hello @nicolacantalupo,
Welcome to the community.
This error pops up usually when the system can not find a .dll file. The best way to resolve this is to install again making sure the .dll installs. Be sure to disable any security software.
  1. Conduct a Clean Uninstall of the application & use the MSfixitTool to complete it
  2. Reboot the computer & log in as Administrator
  3. Clean out the TEMP folder. To open the TEMP folder, type %TEMP% in the address bar of Windows Start Menu and hit Enter (Windows)
  4. Temporarily disable security settings like Antivirus, Firewall & UAC on your Windows operating system
  5. Use the Browser Download Method in your Autodesk Account
Report back on the progress.
Please “Accept As Solution” if a reply or replies have helped resolve the issue or answered your question, to help others in the community.
Message 12 of 14
natasha.l
I wanted to check-in with you, I hope you were able to resolve the installation problems you were having.
Message 13 of 14
the solution you proposed has not solved the problem
Message 14 of 14
Hello Nicola,
Not sure from the thread if you tried that or not, but because the error messages writes about a missing DLL file I would suggest to do the following:
1. Try the following https://www.drivereasy.com/knowledge/api-ms-win-crt-runtime-l1-1-0-dll-missing-error-solved/
2. Another link for similar issue: Update for Universal C Runtime in Windows.
Nicolai Gheorghiev
OpenLM -- Stretching your licenses to their limit
www.openlm.com
