3ds Max Installation fail error 1603
Message 1 of 17
Hi, I downloaded the 3ds max files through the virtual agent. When I install I get the error that some files couldn't be installed and that the installation failed. Attached you can find the installation log. Thank you in advance, Kind regards!
Replies (16)
Message 2 of 17
Otto
Hello x.fiersWimionline and welcome to the Autodesk community!
It looks like you’re seeing Error 1603. Error 1603 is a generic error generated by the Microsoft Windows Installer (MSI) when a problem occurred during the installation of your Autodesk product. The following article(s) should help you resolve the problem:
Error 1603 during installation of Autodesk software
Errors during AutoCAD software installation
Here is some general information about installation, licensing and downloading Autodesk software:
AutoCAD 2012 installation fails on machine with NET 4.5
Previous Versions of Autodesk Software
Installation, Activation and Licensing
If this information was helpful, please consider marking it as an Accepted Solution by clicking on the "Accept as Solution" link, below. Taking a moment to do this will help others with similar questions find useful answers. Thank you!
Kudos (click on the link or the "thumbs-up!" icon), are also gratefully received! (Even a bot likes praise.)
If this answer missed the mark, please let us know so that other community members can lend a hand. Any additional details might help, too: consider including relevant screenshots, log files, error messages, or system specs.
I'm a software-based HelpBot, designed to provide the information you need to get up and running with Autodesk products—any time, day or night. Your feedback will help train me to deliver more accurate and helpful answers. Thanks in advance! Also, please note that I'm only set up to respond to the first post of a topic, not to any replies. Thank you!
Helpful links: Find Serial Numbers and Product Keys | Find Downloads and Service Packs | Activate Autodesk software
Message 3 of 17
That doesn't help, Attached to this post you can find the AIDA zip file
Message 4 of 17
Darin.Green
Download the software from the Autodesk Virtual Agent
Once there, use the Download Links option to navigate to the application you need to download.
NOTE: If there are multiple parts for the download, you'll need to click each part to download them, once they are downloaded double-click Part1 (which will automatically extract the remaining parts) to begin the installation.
If this information was helpful, please consider using the Accept Solution
Message 5 of 17
Hi Darin,
I downloaded the files with the Virtual Agent and installed them.
After installation it still gave me the notification that the installation failed.
Message 6 of 17
Darin.Green
Navigate to c:\users\<username>\appdata\local\temp and grab the installation log files and post them here for review.
Message 7 of 17
Hi, I tried installing Max 2017. I downloaded it through the Virtual Agent. During installation, when it reaches populate data, the setup rolls back to the 3DS max installation again, then back to the material libraries. At a certain point the setup closes and my pc automatically restarts! The uploader isn't working for me (when I choose the file and click "add attachment" the page just jumps upwards) So here is the log file: 2016/8/22:17:55:20 Xfiers XAVIER === Setup started on XAVIER by Xfiers === 2016/8/22:17:55:20 Xfiers XAVIER Path_Length: 157 2016/8/22:17:55:20 Xfiers XAVIER Current Directory C:\Autodesk\Autodesk_3ds_Max_2017_EFGJKPS_Win_64bit 2016/8/22:17:55:20 Xfiers XAVIER Launch 2016/8/22:17:55:20 Xfiers XAVIER CommandLine 2016/8/22:17:55:20 Xfiers XAVIER Path_Length: 157 2016/8/22:17:55:20 Xfiers XAVIER Current Directory C:\Users\Xfiers\AppData\Local\Temp\_AIF4DE.tmp 2016/8/22:17:55:27 Xfiers XAVIER === Setup ended === 2016/8/22:17:55:22 Xfiers XAVIER === Setup started on XAVIER by Xfiers === 2016/8/22:17:55:22 Xfiers XAVIER Path_Length: 157 2016/8/22:17:55:22 Xfiers XAVIER Current Directory C:\Users\Xfiers\AppData\Local\Temp\_AIF4DE.tmp 2016/8/22:17:55:22 Xfiers XAVIER Launch 2016/8/22:17:55:27 Xfiers XAVIER PageOpen LaunchDialog
Message 8 of 17
Since the uploader doesn't work for me you can find the log file here: https://we.tl/UbaCPVtJaY I am looking forward to your feedback
Message 9 of 17
Here you can find the html version of the Autodesk Installation Diagnostic Assistant I executed, maybe this can come to help. Again a wetransfer link since the uploader isn't working (sorry for this inconvenience) https://we.tl/mkoZtCyMaG
Message 10 of 17
Actually here you can find a collection of the html and all the logs altogether: https://we.tl/64Qz4Q6Wn6
Message 11 of 17
Darin.Green
@Anonymous Thanks for the logs.
In regards to the errors you're getting (Error 1603 during the installation of MentalRay) is a general error which could mean anything. That being said, can you log onto the machine as 'Administrator' instead of 'Xfiers' and try running the installation again?
Message 12 of 17
Hi Darin, I logged with the Administrator profile like you said. My pc didn't restart automatically during the installation, however I am getting the same error. The installation is rolling back after the Populate Data install section. 2016/8/22:21:38:36 Administrator XAVIER === Setup started on XAVIER by Administrator === 2016/8/22:21:38:36 Administrator XAVIER Path_Length: 157 2016/8/22:21:38:36 Administrator XAVIER Current Directory C:\Autodesk\Autodesk_3ds_Max_2017_EFGJKPS_Win_64bit 2016/8/22:21:38:36 Administrator XAVIER Launch 2016/8/22:21:38:36 Administrator XAVIER CommandLine 2016/8/22:21:38:36 Administrator XAVIER Path_Length: 157 2016/8/22:21:38:36 Administrator XAVIER Current Directory C:\Users\ADMINI~1\AppData\Local\Temp\_AID61C.tmp 2016/8/22:21:38:38 Administrator XAVIER === Setup ended === 2016/8/22:21:38:37 Administrator XAVIER === Setup started on XAVIER by Administrator === 2016/8/22:21:38:37 Administrator XAVIER Path_Length: 157 2016/8/22:21:38:37 Administrator XAVIER Current Directory C:\Users\ADMINI~1\AppData\Local\Temp\_AID61C.tmp 2016/8/22:21:38:37 Administrator XAVIER Launch 2016/8/22:21:38:39 Administrator XAVIER PageOpen LaunchDialog 2016/8/22:21:38:42 Administrator XAVIER PageOpen LicenseDialog 2016/8/22:21:38:44 Administrator XAVIER PageOpen ProductInfoDialog 2016/8/22:21:38:44 Administrator XAVIER PageOpen ProductSelectionDialog2 2016/8/22:21:38:57 Administrator XAVIER PageOpen FullProgressDialog 2016/8/22:21:38:57 Administrator XAVIER Installing Microsoft Visual C++ 2012 Redistributable (x86): "C:\Autodesk\Autodesk_3ds_Max_2017_EFGJKPS_Win_64bit\3rdParty\x86\VCRedist\2012UPD4\vcredist_x86.exe" /install /quiet /norestart 2016/8/22:21:39:00 Administrator XAVIER Install Microsoft Visual C++ 2012 Redistributable (x86) Succeeded 2016/8/22:21:39:00 Administrator XAVIER Installing Microsoft Visual C++ 2012 Redistributable (x64): "C:\Autodesk\Autodesk_3ds_Max_2017_EFGJKPS_Win_64bit\3rdParty\x64\VCRedist\2012UPD4\vcredist_x64.exe" /install /quiet /norestart 2016/8/22:21:39:00 Administrator XAVIER Install Microsoft Visual C++ 2012 Redistributable (x64) Succeeded 2016/8/22:21:39:00 Administrator XAVIER Installing Microsoft Visual C++ 2013 Redistributable (x86): "C:\Autodesk\Autodesk_3ds_Max_2017_EFGJKPS_Win_64bit\3rdParty\x86\VCRedist\2013\vcredist_x86.exe" /q /norestart /l C:\Users\ADMINI~1\AppData\Local\Temp\vcredist_x86_2013.log 2016/8/22:21:39:00 Administrator XAVIER Install Microsoft Visual C++ 2013 Redistributable (x86) Succeeded 2016/8/22:21:39:00 Administrator XAVIER Installing Microsoft Visual C++ 2013 Redistributable (x64): "C:\Autodesk\Autodesk_3ds_Max_2017_EFGJKPS_Win_64bit\3rdParty\x64\VCRedist\2013\vcredist_x64.exe" /q /norestart /l C:\Users\ADMINI~1\AppData\Local\Temp\vcredist_x64_2013.log 2016/8/22:21:39:01 Administrator XAVIER Install Microsoft Visual C++ 2013 Redistributable (x64) Succeeded 2016/8/22:21:39:01 Administrator XAVIER Installing Autodesk® Material Library 2017 - Medium Resolution Library: ADSK_EULA_STATUS=#1 MUILANG=en-us SETUP_PACKAGENAME="Autodesk 3ds Max 2017" SETUP_PACKAGECODE={8E850B3E-B21A-4790-0664-7CCB73BD8B3B} SETUP_UNINSTALLKEYS=1 SETUP_ISLANGUAGEPACK=0 SETUP_PRODUCTDEPENDENCIES="{8FB9F735-D64C-4991-8D91-4CDDAB1ABDEE},;;;;" PACKAGEUPI={66E9D963-1A7E-4E18-884F-8F66BCE51125} ADSK_SOURCE_ROOT="C:\Autodesk\Autodesk_3ds_Max_2017_EFGJKPS_Win_64bit\" FILESINUSETEXT="" REBOOT=ReallySuppress ADSK_SETUP_EXE=1 2016/8/22:21:39:16 Administrator XAVIER Install Autodesk® Material Library 2017 - Medium Resolution Library Succeeded 2016/8/22:21:39:16 Administrator XAVIER Installing Autodesk® Material Library 2017 - Advanced Material Image Library: ADSK_EULA_STATUS=#1 MUILANG=en-us SETUP_PACKAGENAME="Autodesk 3ds Max 2017" SETUP_PACKAGECODE={8E850B3E-B21A-4790-0664-7CCB73BD8B3B} SETUP_UNINSTALLKEYS=1 SETUP_ISLANGUAGEPACK=0 SETUP_PRODUCTDEPENDENCIES="{8FB9F735-D64C-4991-8D91-4CDDAB1ABDEE},;;;;" PACKAGEUPI={66E9D963-1A7E-4E18-884F-8F66BCE51125} ADSK_SOURCE_ROOT="C:\Autodesk\Autodesk_3ds_Max_2017_EFGJKPS_Win_64bit\" FILESINUSETEXT="" REBOOT=ReallySuppress ADSK_SETUP_EXE=1 2016/8/22:21:39:19 Administrator XAVIER Install Autodesk® Material Library 2017 - Advanced Material Image Library Succeeded 2016/8/22:21:39:19 Administrator XAVIER Installing Autodesk Licensing Manager: TRANSFORMS="C:\Users\ADMINI~1\AppData\Local\Temp\_AID61C.tmp\x64\CLIC\CLIC_x64_Release-standalone.mst" ADSK_EULA_STATUS=#1 ADSK_SOURCE_ROOT="C:\Autodesk\Autodesk_3ds_Max_2017_EFGJKPS_Win_64bit\" FILESINUSETEXT="" REBOOT=ReallySuppress ADSK_SETUP_EXE=1 2016/8/22:21:39:28 Administrator XAVIER Install Autodesk Licensing Manager Succeeded 2016/8/22:21:39:28 Administrator XAVIER Installing Autodesk® 3ds Max® 2017: TRANSFORMS="C:\Users\ADMINI~1\AppData\Local\Temp\_AID61C.tmp\x64\max\3dsMax-standalone.mst" ADSK_EULA_STATUS=#1 ADSK_SOURCE_ROOT="C:\Autodesk\Autodesk_3ds_Max_2017_EFGJKPS_Win_64bit\" INSTALLDIR="C:\Program Files\Autodesk\3ds Max 2017\" FILESINUSETEXT="" REBOOT=ReallySuppress ADSK_SETUP_EXE=1 2016/8/22:21:41:34 Administrator XAVIER Install Autodesk® 3ds Max® 2017 Succeeded 2016/8/22:21:41:34 Administrator XAVIER Installing Autodesk® Populate Data for 3ds Max 2017: ADSK_EULA_STATUS=#1 MUILANG=en-us SETUP_PACKAGENAME="Autodesk 3ds Max 2017" SETUP_PACKAGECODE={8E850B3E-B21A-4790-0664-7CCB73BD8B3B} SETUP_UNINSTALLKEYS=1 SETUP_ISLANGUAGEPACK=0 SETUP_PRODUCTDEPENDENCIES=";;;;" PACKAGEUPI={66E9D963-1A7E-4E18-884F-8F66BCE51125} ADSK_SOURCE_ROOT="C:\Autodesk\Autodesk_3ds_Max_2017_EFGJKPS_Win_64bit\" FILESINUSETEXT="" REBOOT=ReallySuppress ADSK_SETUP_EXE=1 2016/8/22:21:43:19 Administrator XAVIER Install Autodesk® Populate Data for 3ds Max 2017 Succeeded 2016/8/22:21:43:19 Administrator XAVIER Installing NVIDIA mental ray and IRay feature plugins for 3ds Max 2017: ADSK_EULA_STATUS=#1 MUILANG=en-us SETUP_PACKAGENAME="Autodesk 3ds Max 2017" SETUP_PACKAGECODE={8E850B3E-B21A-4790-0664-7CCB73BD8B3B} SETUP_UNINSTALLKEYS=1 SETUP_ISLANGUAGEPACK=0 SETUP_PRODUCTDEPENDENCIES=";;;;" PACKAGEUPI={66E9D963-1A7E-4E18-884F-8F66BCE51125} ADSK_SOURCE_ROOT="C:\Autodesk\Autodesk_3ds_Max_2017_EFGJKPS_Win_64bit\" FILESINUSETEXT="" REBOOT=ReallySuppress ADSK_SETUP_EXE=1 2016/8/22:21:43:21 Administrator XAVIER Install NVIDIA mental ray and IRay feature plugins for 3ds Max 2017 Succeeded 2016/8/22:21:43:21 Administrator XAVIER Installing NVIDIA mental ray and IRay rendering plugins for 3ds Max 2017: ADSK_EULA_STATUS=#1 MUILANG=en-us SETUP_PACKAGENAME="Autodesk 3ds Max 2017" SETUP_PACKAGECODE={8E850B3E-B21A-4790-0664-7CCB73BD8B3B} SETUP_UNINSTALLKEYS=1 SETUP_ISLANGUAGEPACK=0 SETUP_PRODUCTDEPENDENCIES=";;;;" PACKAGEUPI={66E9D963-1A7E-4E18-884F-8F66BCE51125} ADSK_SOURCE_ROOT="C:\Autodesk\Autodesk_3ds_Max_2017_EFGJKPS_Win_64bit\" FILESINUSETEXT="" REBOOT=ReallySuppress ADSK_SETUP_EXE=1 2016/8/22:21:43:23 Administrator XAVIER Install NVIDIA mental ray and IRay rendering plugins for 3ds Max 2017 Failed Installation aborted, Result=1603 2016/8/22:21:43:24 Administrator XAVIER Rollback NVIDIA mental ray and IRay feature plugins for 3ds Max 2017 Succeeded 2016/8/22:21:45:03 Administrator XAVIER Rollback Autodesk® Populate Data for 3ds Max 2017 Succeeded 2016/8/22:21:47:11 Administrator XAVIER Rollback Autodesk® 3ds Max® 2017 Succeeded 2016/8/22:21:47:22 Administrator XAVIER Rollback Autodesk Licensing Manager Succeeded 2016/8/22:21:47:22 Administrator XAVIER Rollback Autodesk® Material Library 2017 - Advanced Material Image Library Succeeded 2016/8/22:21:47:24 Administrator XAVIER Rollback Autodesk® Material Library 2017 - Medium Resolution Library Succeeded 2016/8/22:21:47:24 Administrator XAVIER Rollback Microsoft Visual C++ 2013 Redistributable (x64) Failed Installation aborted, Result=1619 2016/8/22:21:47:24 Administrator XAVIER Rollback Microsoft Visual C++ 2013 Redistributable (x86) Failed Installation aborted, Result=1619 2016/8/22:21:47:24 Administrator XAVIER Rollback Microsoft Visual C++ 2012 Redistributable (x64) Failed Failure is ignored, Result=1619 2016/8/22:21:47:24 Administrator XAVIER Rollback Microsoft Visual C++ 2012 Redistributable (x86) Failed Failure is ignored, Result=1619
Message 13 of 17
Darin.Green
Ok, its failing on the same thing. Try browsing to the msi file for MentalRay and install just mentalray to see what it says...
C:\Autodesk\Autodesk_3ds_Max_2017_EFGJKPS_Win_64bit\x64\MENTALRAY\Mentalray2017.msi
Message 14 of 17
Hi Darin, NOT installing the Mental Ray and Iray renderers during installation actually did the trick. Thank you very much! However, installing the Mentalray2017.msi manually does not work, I have no Iray or Mental Ray renderers available in 3DS Max. Apart from that, thank you very much for your help!
Message 15 of 17
eduardovbonfim
Observer
Observer
Hey i got the same error yesterday, the solution ive found was, uninstalling all microsoft C++ 2005 from the control panel, them after that
you start the software again and hit to install the program. ( I think there`s some kind of conflits sometimes, and i believe that later on updates you can install the C++ 2005 again.
Cheers!
Message 16 of 17
bigdude409
Please stop marking these 1603 install issues as 'solved'.  It's a generic error with many different (unrelated) fixes.
Message 17 of 17
Mark.Lancaster
@bigdude409
Keep in mind just because a  certain forum posting or reply related to a similar issue you're faced with and got marked as a solution by another user, doesn't mean its a solution for everything...  😁
Mark Lancaster
