Announcements
Announcement: We’re aware of an issue affecting starting a new topic from category pages and creating new blog posts. New topics can still be started directly from the relevant board. Learn more here.
3Ds Max files icon problem
Message 1 of 44
Hi, there ..
I used to work on 3Ds max design 2014 for a quite while ..
then I decided to upgrade to 2015 ..
I installed 2015, and I made sure that evertything is okay .. then I uninstalled the 2014 version to spare space on my hdd
after uninstalling the 2014 version, all 3ds max files on my machine don't show the 3ds max icon for no reason !!!! ( check the attatchment )
i tried to figure that out, with no luck !!!
I tried to uninstall the 2015 version and reinstall it. and it didn't work !!
I know that it's not a major problem .. but it's really annoying !!!!
( I use windows 8.1 btw )
Replies (43)
Message 21 of 44
What worked for me, was to reset the all application and icon file paths in Windows.
Simply go to:
start > settings > Apps > Default apps > Scroll down to "Reset to the Microsoft recommended defaults" and click "Reset".
Worked for 3ds max 2018, after upgrading from 2016.
Message 22 of 44
For those who cant find 3ds max in <<Choose  default Program>> list
You must check if the 3ds Max path is right in Registry Editor. This method worked for me !!!
In my case there was linked 2014 version but my current version is 2018.
You need to do this steps
Copy your new 3ds max exe link
Then past it into 3ds max registry file
 regedit  >   HKEY_CLASSES_ROOT   >  max_auto_file > shell > open > command > in right window you will see file with 3ds max link  > chose that file , it will have name (Default) Right click on that and chose Modify > Past link there in Value Data.    After  this steps cloth registry . Select damaged 3ds file > right click  > open with > and choose 3ds max(it will be appeared there !!! )
Message 23 of 44
rene_alex
The solution in this thread did not work for me, (win 10 Max 2019) but this tiny app fix it without restart in a heartbeat
http://www.nirsoft.net/utils/file_types_manager.html
Run it is a tiny exe file
edit menu Find
type max
scroll to the .max entry
right click on it and click on Edit File Type or press F2
Click on the (...) at the Default icon entry look for the icon in the dialog box (there is only one)
click OK and OK in the Edit File Type box
It should refresh and get fixed right there.
Hope it helps
Message 24 of 44
renar-visuals
Nothing in this thread worked for me, but the video below solved it for me. I had to create the max_auto_file, shell and DefaultIcon keys by myself because they weren't there initially:
3ds Max subscription customer since 2010
| Max 2022.1 | AMD Threadripper 3970X 32-core | 64GB RAM | Nvidia GeForce GTX 1080 Ti FE 11GB | NVMe SSD Samsung 960 Pro | Win10 Pro x64 | Nvidia Driver 466.47
Message 25 of 44
ggarza
Honestly.. now.. after every annual update of 3dsMax, I'm stuck finding a new solution. I'm thoroughly confused that Autodesk doesn't seem to understand how to create programs that can install correctly. Every.. single.. time.. my icons are get screwed up. No other program on my machine in the last 5 years does this. ONLY 3dsmax. ????
Message 26 of 44
thank you @Anonymous and @Anonymous ...
this solution from @Anonymous is working good for me on win10 and 3ds max 2019
Message 27 of 44
Hi i had this problem too, or so, it seems that only .3ds files are having this mismatch with the icon.
I opend the "Regedit" but simply the key "max_auto_files" doesn't exist on my registry.
I created the key myself, first the "Shell" key (Shell/open/command ) like the post of @Anonymous  shows and then I created the "DefaultIcon" Key (max_auto_file/ DefaultIcon)like in the post of @ggarza  but nothing has changed.
Any Idea?
Message 28 of 44
ITS WORKING....THANKS A LOT
Message 29 of 44
jennifer_tan
I basically tried everything for 2 days and was really giving out and finally your method works!
and of cos beside the "max_auto_file" i also add in defaultIcon in under applications - 3dsmax.exe also which i dont know if this is the solution, whichever it is. it works
Message 30 of 44
it did not solve my problem , please help
Message 31 of 44
did you find other solution , if you did please tell me. I am facing same problem .
Message 32 of 44
didnt work
Message 33 of 44
Its nearly 2020, and Ive just had the same issue. This solution is still relivant and still works 5 years later. Simply taking the time to say thankyou @ggarza
Message 34 of 44
Hi, in my case there is no file called max_auto_file. Any idea?
Message 35 of 44
petr.titera
Observer
Observer
This worked for me right away. I didn't find the line in registry
Message 36 of 44
jennifer_tan
if you do the reset, it will affect the other rest of your program linking it back to windows preferred programs.
not a good idea
Message 37 of 44
3Ds Max files icon problem so plz set the 3Ds Max  icon
Message 38 of 44
Message 39 of 44
I did this and its half works because i can se the icon but now i have another problem that its open my file like if it is a new one so i cant se my stuff. Please Help!!!
Message 40 of 44
ggarza
Unfortunately, I had that post years and years ago. It was a solution that worked for me well at the time. But, honestly, every time I update my Autodesk Suite, there are a lot of the same Icon, Execution, File Extension/Program issues. I always am able to come up with a workable solution for myself. I can't say HOW to fix this, but it seems for some reason your unique files (your working saved files) have not only taken the proper Icon, but are launching as the standard 3dsm executable. I'm not sure the exact way to fix this. My original fix is simply borrowing the "exe ICON" graphic, and applying/associating it with the missing "file ICON".
A new solution to this ongoing 3dsm icon problem is certainly different by now.. especially if you have Windows 10, and the latest 3dsm. Sorry I can't help more than that.
