3Ds Max 2018 Installing Problem
I have a problem with the new 3Ds Max 2018 Installation Page
It gets stuck at the 7 of 12 page
Here is a picture that explains it
PLZ Help
and thanks
Fadhil_Farook
Don't you get any error messages? It shows that it's still downloading too.
Mark.Lancaster
You are using the install now method that's fails most time.
There's a couple of ways to properly download and install your Autodesk product to your machine.  Please review this article and the solution it provides.
If the installation does fail using the preferred methods, please post your installation log file here so we can review it.
Posting info: Sometimes the installation log file contains the serial # that was assigned to you.  Open your log file using Windows Notepad and perform a search on "/SN".  Depending on the number of installation attempts, your serial # may be located throughout the log file.  If present, remove or "X" out your serial # prior to posting.
Good luck on your installation and report back on your progress.
Mark Lancaster
