@gary.allison73
However the problem... The main user's who monitor and support this forum are not really 3DS Max Users and/or Experts so mostly like we don't have the answer here. If you didn't get any response from the actual users in the 3DS Max forum, then mostly likely no one here will even know how to resolve this.
However when I did a search I found another forum (not in the Autodesk community) and someone stating they were having this same sort of issue in 2014 and another person stated it sounded like something was messed up in your Windows profiles. They recommended that you try closing max, back up and delete everything in here: "C:\Users\<username>\AppData\Local\Autodesk\3dsMax\<year version> - 64bit\ENU", restart max. I will leave that up to you if you want to try it but I'm not a 3DS Max user/expert and I have no clue if doing this will impact anything or not..
In the end if this is a free/student/educational license you really don't get support from Autodesk since the software was free. You only have the forum for your support.
If this is commercial license then you get support from Autodesk by logging a support case in your Autodesk Account or through your reseller.
Mark Lancaster
& Autodesk Services MarketPlace Provider
