2023 Installation - Wont install on 2nd drive
LRW-ITSupport
LRW-ITSupport
Has anyone else had any issues installing AutoCAD 2023 to a 2nd drive?
Ive just gone to install 2023 and i dont have enough space on my C: drive... Not an issue ive got over 1TB free on my 2nd drive.. Created my own Autodesk folder on D drive and navigated to that location when the install wizard asks me where to install... Click Next, then i get a error message that autocad wont install due to not enough space on C: drive, i then have to cancel the install and start again to make sure i selected the correct location (sometimes we make mistakes). Nope same thing, DEFINITELY selected the right location.
Any help is welcome, apart from "clean up C:" - Its as clean as can be for now, i need to get it working from D drive as im going to reinstall all my other autodesk products there as long as i can get this working.
Cheers
Accepted solutions (3)
pendean
Community Legend
Community Legend
There is still a good chunk of the program that installs on the OS primary drive, and there is no workaround for that. Sorry.
DarrenP
multiple threads on this
read this: http://forums.autodesk.com/t5/installation-licensing/out-of-disk-space-during-installation-to-anothe...
DarrenP
mdavis22569
System requirements for AutoCAD 2023 including Specialized Toolsets (Windows)
Operating System 64-bit Microsoft® Windows® 11 and Windows 10 version 1809 or above. See Autodesk's Product Support Lifecycle for support information.
That's why ...
Try cleaning up some space by extracting it to your 😧 Drive
Moving everything you can from the C:\Autodesk folder to the 😧 drive
Clean out the temp folder
See if that gets you space.
If you have older versions installed you might need to remove some
Mike Davis
