2016BDS Deployment - Extremely Long Install
I've done a couple deployments now for Building Design Suites 2016. I did all the apps I wanted... AcadMEP, Inventor, NavisManage and Revit. I did Add Updates when I built the deployments... and added them all.
The First Couple Test Installations ran very long. 10 hours in case...
Troubles:
- Updates for Revit 2016 are goofy. At one point the Installation seemed to halt dead in its tracks... then out of now were a dialog asking me to download and install a Revit Update... C:\Autodesk is where it wanted it asked to go. Then I got... 'There is already an install running, please wait till after it is finished. After a good while, I ended up task managering out of the update itself. Then the install from the deployment seemed to pick back up. This one took better than 8 hours.
- The second machine I left over night... then came back the next day. After 18 hours It was stuck dead. I ended up task managering out of it. I did test the apps... all seemed to work.
- I decided to turn of 'Silent Install' cause a few years ago I kind of got burned... seeing the full blown install seemed a bit more reassuring that I could see exactly what was happening. Anyway I decided to turn on 'Silent Install'... well the switch said it was on, but the actual install was not Silent. (as if I didn't turn it on)
I can't have installs taking hours with as many machines as I have to do.
I am rebuilding the deployment without the Udates and Silent Install.
For fear of installations taking hours on end... I did specific single softwares in a deployment.
The best practice... I would assume is to do a full image with ALL the softwares toggled to install... then spin off other deployments within the image.
Does anyone have any words of wisdom?
