2016BDS Deployment - Extremely Long Install
mdhutchinson
Advisor Advisor
mdhutchinson
I've done a couple deployments now for Building Design Suites 2016. I did all the apps I wanted... AcadMEP, Inventor, NavisManage and Revit. I did Add Updates when I built the deployments... and added them all.
The First Couple Test Installations ran very long. 10 hours in case...
Troubles:
  1. Updates for Revit 2016 are goofy. At one point the Installation seemed to halt dead in its tracks... then out of now were a dialog asking me to download and install a Revit Update... C:\Autodesk is where it wanted it asked to go. Then I got... 'There is already an install running, please wait till after it is finished. After a good while, I ended up task managering out of the update itself. Then the install from the deployment seemed to pick back up. This one took better than 8 hours.
  2. The second machine I left over night... then came back the next day. After 18 hours It was stuck dead. I ended up task managering out of it. I did test the apps... all seemed to work.
  3. I decided to turn of 'Silent Install' cause a few years ago I kind of got burned... seeing the full blown install seemed a bit more reassuring that I could see exactly what was happening. Anyway I decided to turn on 'Silent Install'... well the switch said it was on, but the actual install was not Silent. (as if I didn't turn it on)
I can't have installs taking hours with as many machines as I have to do.
I am rebuilding the deployment without the Udates and Silent Install.
For fear of installations taking hours on end... I did specific single softwares in a deployment.
The best practice... I would assume is to do a full image with ALL the softwares toggled to install... then spin off other deployments within the image.
Does anyone have any words of wisdom?
Otto
Hello mdhutchinson
It looks like you are stuck at the activation/installation step while attempting to download software, or are having problems with starting your software immediately after installing. The following article(s) should help you resolve the problem:
Communication Failure message during download and installation - Note that this article also provides alternate downloading and installation methods.
Application Manager Update stuck at installing
In order to manually activate your software (in cases where the activation appears stuck), please refer to Manually Activating Your Autodesk Software.
If the activation window is not displayed, others have resolved this by completely uninstalling and reinstalling their software. Please refer to How to Remove all Software from a Windows System for assistance.
If this information was helpful, please consider marking it as an Accepted Solution by clicking on the "Accept as Solution" link, below. Taking a moment to do this will help others with similar questions find useful answers. Thank you!
Kudos (click on the link or the "thumbs-up!" icon), are also gratefully received! (Even a bot likes praise.)
If this answer missed the mark, please let us know so that other community members can lend a hand. Any additional details might help, too: consider including relevant screenshots, log files, error messages, or system specs.
I'm a software-based HelpBot, designed to provide the information you need to get up and running with Autodesk products—any time, day or night. Your feedback will help train me to deliver more accurate and helpful answers. Thanks in advance! Also, please note that I'm only set up to respond to the first post of a topic, not to any replies. Thank you!
Helpful links: Find Serial Numbers and Product Keys | Find Downloads and Service Packs | Activate Autodesk software
