1608 install errors
1608 install errors
1608 install errors
Unable to solve 1608 errors. Infrastructure Design Suite won't install. At this for 2 days now - very frustrating!
Tried all of these 1603 error related to Microsoft Visual C ++ Redistributable
Otto
Hello clarence.lambert and welcome to the Autodesk community!
It looks like you are seeing a Windows Installer Error Message. The following article(s) should help you resolve the problem:
Windows Installer Error Messages
Errors during AutoCAD software installation
If this information was helpful, please consider marking it as an Accepted Solution by clicking on the "Accept as Solution" link, below. Taking a moment to do this will help others with similar questions find useful answers. Thank you!
Kudos (click on the link or the "thumbs-up!" icon), are also gratefully received! (Even a bot likes praise.)
If this answer missed the mark, please let us know so that other community members can lend a hand. Any additional details might help, too: consider including relevant screenshots, log files, error messages, or system specs.
I'm a software-based HelpBot, designed to provide the information you need to get up and running with Autodesk products—any time, day or night. Your feedback will help train me to deliver more accurate and helpful answers. Thanks in advance! Also, please note that I'm only set up to respond to the first post of a topic, not to any replies. Thank you!
Helpful links: Find Serial Numbers and Product Keys | Find Downloads and Service Packs | Activate Autodesk software
KMLCAD
Hi clarence.lambert and welcoem to the community!  The best way to solve this particular error would be to follow this isntallation workflow:
Please be sure to follow these tips to prepare your system before install.  Also be sure to turnoff any antivirus/firewall and lower your UAC:
1.) Ensure you are installing the software as an administrator.
2.) Ensure you have Microsoft .NET Framework 4.0 (or 4.5) installed. It will appear in your Add/Remove Programs in Control Panel. If it is not installed, install the package from here (www.microsoft.com/download/en/details.aspx?id=17718)
3.) Temporarily disable any antivirus/firewall (very important) scanning during the installation.
4.) Disable UAC on the system (http://windows.microsoft.com/en-US/windows-vista/Turn-User-Account-Control-on-or-off)
5.) Clean out your temp folder Start-Search-%temp%
Then redownload from the virtaul agent and try the install again.
Kevin.L
Customer Service Technical Specialist
Installation and Licensing Forum | Up and Ready Blog | Up and Ready Webinar
