Correct Daylight Factor in Lighting Analysis
When using a Daylight Factor Sky, Sky Model. It shouldn't  take the location in consideration (I don't think it do - but show as it does).
And the Date/Time and Solar Data should be irrelevant to a Daylight Factor it should be visible, with a grey-out or something..
And lastly, as it is a Daylight Factor - the Illuminance settings are in Lux, and not percentage. As it should be when it is a Daylight Factor..! unfortunately this affects the schedules result, -which you can change afterwards - but it is annoying and confusing!!!
1 Comment
scheerd
Thanks for the suggestions, they are definitely known and high on the priority list.
I wanted to let you know about the new release, which includes an export feature that supports DF by exporting Room ADF (and average Room illuminance) values.  This is sort of a preview of our work on the Daylight Factor Analysis Type.
https://insight.autodesk.com/oneenergy/Landing/Download
The new feature is available by checking the Settings (gear icon) box for 'Create CSV Points Results' before generate results for a completed run.  This will export CSV files for raw point illuminance and average Room illuminance to <mydocs>/Autodesk/RevitDaylighting.  If you do an Illuminance run using the 'Daylight Factor Sky Model', the results will yield DF and ADF.
David
