Roadside Open Ditching - Expanded Support
I work for a county entity and very seldomly do we go for storm drainage as it is very expensive in rural areas.  i'd love to see drainage support for open grade ditching for roadside ditching.  So far infraworks is great for inner city work, but it misses a big point for the work i do as a county engineer. being able to easily build a road model based on lidar and then giving the system a minimum daylight + maximum daylight which changes it to storm after a certain depth would be great.  Most if not all of our drainage is simply open cut or storm with T-inlets along a swale on the surface to keep our road bed dry.
2 Comments
kksabah888
The inclusion of roadside open channel/ditch drain in Infraworks are useful especially in tropical monsoon area.  The mandatory  design of such open ditch in tropical area has make designer to be aware of the  confined boundary  when come to presenting the building footprint available after deducting the open ditch area.
https://images.app.goo.gl/BVsj3JvuxfY8P9xG7
nigel_haynes
Observer
Any updates Autodesk? There is a great need for the open roadside drain option (Vee, trapezoidal, swale....).
