This idea stems from a question posted to the IW forum.
Roads Design Criteria - Other than AASHTO
The idea here is 2 fold. Allow:
- custom design criteria created for Civil3D (.xml) to be transferred/converted for use in InfraWorks (.clp).
- alignments created in Civil3D that have used a custom criteria file other than the OTB criteria (AASHTO, etc) for horiz, vertical and superelevation calcs should be able to pass that information on to IW (even if a companion IW criteria is not present). Currently only the Horz/Vert geometry will get used, but will likely be flagged as invalid in some cases. The superelevation will be re-calc'd using the AASHTO std.
