Join roads to create single object
I would like to see an option to join multiple roads together to create single road objects in Infraworks.  As far as I can find, two roads can be visually joined end to end to create what appears to be a single road in the model, but the two pieces will remain separate objects in the database and in the behavior of the drawing.
I would like an option to join the two roads together so it becomes one single road instead of remaining two separate objects.
It would allow for design restrictions where you may need to meet requirements for connection point or angle of connection at both ends and allow you to design toward the middle from the connecting points on both sides.
Would also allow you to then drag and drop to change the style for the entire road at once instead of repeating the process for each segment.
Roads that are generated by model builder as separate entities could to be "cleaned up" and combined to create single roads where they should be one continuous piece.
4 Comments
Agreed.
Has this been addressed?
blake_feehely
Hi there,
Also the ability to split component roads would be equally powerful, particularly with road lengths exceeding 10km
Kind regards
i have the same problem, i need to connect two compond roads (already designed) in order to make them a single road not just for visualization.
pieter_haeck
Simple feature that could make lives of a designer so much easier... Please address this...
