Integration of Topobase data from MAP3D in INFRAWORKS wastewater functionality and a workflow between both products.
We can use the coordinates (also the Z-coordinate), the dimension, the material etc to generate the graphical representation.
Also using the configuration of dialogs inside MAP3D to show and edit the metadata of the objects.
With this functionality it is possible with small work to integrate teh as build in teh visualisation of new projects.
And also to integrate planed projects with the status planed inside the managing of as build.
