Import/Export Point files
This could be applied in many different scenarios but for instance a .csv file with tree data and lat/long.  Or possibly survey control point data imported as Points of Interest (see attached csv file as example). I would prefer to see this functionality accepted as a non specific data type (meaning apply import to any feature type as required including buildings) and it needs to be direct import rather than a specific script.  This would require the user to manually select the appropriate fields in the csv file or create a standard import/export format with availability of custom fields.
2 Comments
george.hatch
this is once again valuable for other customers...and other use cases.  Feel free to ask for more explanation if needed.
ramesh_sridharan
Status changed to: Archived
@george.hatch I understand this was an old post but there is a workaround to import CSV as point of interest as in this link http://civil-community.autodesk.com/2016/12/bring-survey-points-into-your-infraworks-360-model-from-...
I can send you a video and sample file offline, if you want. Given there is already some workflow and not a lot of votes for this idea, let me archive this for now.
Rail Community
