Implement Box girder
I would like to suggect implementing box girder deck type in INFRAWORK as it currently includes only beam and slab deck
10 Comments
ara.ashikian
Hi Ahmed
The upcoming Spring 2016 release of InfraWorks 360 will allow users to access their own parametric custom girder sections.  This option is currently available in the Rolling sand box version.  The custom parametric sections would be created in Project Kameleon, which leverages Inventor and then published to the InfraWorks 360 model.  The following images illustrate this capability. We are also working on some refinements, such as the ability to change any of the girder dimensions at different offsets along the length of the span.
-Ara
PM InfraWorks / Bridges
Eric_Chappell
Status changed to: Accepted
looks real nice!
can you share the custom section shown in your post?
Francois
ara.ashikian
Hi Francois
The next InfraWorks 360 release (in a few weeks), will include a multi-cell concrete box girder section as shown below.
-Ara
Does the latest release of Infraworks 360 include the box girder bridges or it is still under development?, I tried to find that section but i could not?
ara.ashikian
The upcoming 2017.3 release will include this functionality.  This release is now expected to be out in December,
-Ara
mporretto
Hi All,
I'm using IW 360 2017.3, but I did not find this functionality.
Is this functionality already available?
Thanks in advance and I'm sorry about my english.
Marcello Porretto
Rio de Janeiro / Brasil
mporretto
I found it...
Thanks!
i am using INFRAWORKS 360  2018 but still only steel plate girder and Conc.girders are available
could you please help if i can draw the section of box girders
austin_jephson
The multicell box girder shown above is listed as one of the concrete girders.  On a concrete girder bridge, change the girder group 'number of girders' to one, then drill down to select the girder and change the girder type.  In the catalog of concrete girders, you can search for 'multicell' to find it.  There are also steel plate and steel tub girders listed in that catalog, which can be added to a 'concrete' girder bridge.
BTW, we are planning to remove the concept of Concrete, or Steel Plate girder bridges, so that any bridge can be comprised of any type of girder.  i.e. concrete approach spans with steel main spans.
Hope this helps!
Austin
