We are currently experiencing an issue impacting some Autodesk Products and Services - please refer to the Autodesk Health Dashboard for updates.
Disable Dynamic Update when Editing in Profile View
This is part 3 of an Idea submitted by @KPerison http://forums.autodesk.com/t5/infraworks-360-ideas/horizontal-vertical-editing-of-design-roads/idi-p...
"In order to facilitate quicker edits of the horizontal/vertical components and reduce the amount of realtime regeneration the model has to calculate please incorporate:
3.  Disable dynamic update of the model when editing Horiz/Vertical alignments until the user is finished making edits, then update. Allow user to toggle dynamic update on/off or manually start an update."
7 Comments
Eric_Chappell
The ability to disable automatic update when editing in profile was implemented in version 2016.4. When this is turned off, the model updates when the cursor leaves the Profile View window.
Eric_Chappell
If you consider this as implemented, I may see part of the problem getting this software used widely.  I need to be able to edit all the grips in plan and profile and only have the model update when I tell it to.  Triggering an update because the cursor moved of one panel of the software is completely unusable.  I'm going to have to go back to Civil 3D to get through this preliminary design, because the wait time is killing me.
The Auto update model works good.However,when the cursor leaves the profile panel,entire profile view fits(horizontally and vertically)in the panel,thus losing the point zoomed to while editing. Anyway to disable that feature ?I am currently using Infraworks 2018.
Where is this disable feature in the later versions? I'm on 2019 and I dont have that check box in my profile view
llavayenMG53S
@Anonymous  did you find the option in the latest release?
havard_glosli
