Copy to Proposal
Copy to Proposal
If I'm 3 or 4 (or 30 or 40) proposals into a project and I decide to add something to the base, I need to add it to all proposals (or perhaps three fourths of them). This is time consuming and brain numbing and should be automated. In the right click menu, there should be an option to "Copy to proposal". This would then bring up a list of your proposals and you can select which ones the object(s) would be copied to.
4 Comments
And it need it neeeds to remeber which explorer class it belongs to.
Se my idea of import same model to several proposals.
mathewkol
I guess update if you're editing an existing item.  Simple copy if your're adding a new item.
TrevN
While you can do this with some objects, we need the ability to copy ALL objects from one proposal to another
ramesh_sridharan
Brian, Is this for newly added features/records or full data source or something else. Do you see the workflow as user selects a bunch of features in canvas and/or data source(s), Right-click to choose "Copy to Proposal", select necessary proposal(s)?
If there is any duplicate or mismatches or change in design that happens due to this "selected" change on the proposal which user did not see yet, should it be highlighted?
