Coordinate System
Coordinate System
Coordinate System is the Nightmare for me in Infra-works, i hope it will be more easily to help me collect the the site layout in one single model to make Single Source of Truth.
3 Comments
ramesh_sridharan
Status changed to: Gathering Support
@Mohamed-Nassar CAn you please elaborate the request? Are you having trouble assigning or exporting? If export, what format are you trying? Can you also specify what IW version you are using?
Mohamed-Nassar
iam Using Infraworks 2020 i need to import in infraworks my site layout from revit and from Civil 3D, i faced this problem because coordinates system
ramesh_sridharan
@Mohamed-Nassar Can you please add more details? If C3D DWG or the IMX you export from C3D Drawing contains a coordinate system, IW should be able to pick that up and use it. If not, you should be able to assign one. Here is one of the links for the Revit.
