Consistent project offset and better interoperability
One small step that I would like is to have the option to set to set a constant project offset in the model parameters and then have that available to all model users on export and import of a 3d models. This would provide better flow between 3ds max and InfraWorks I often transfer data to 3ds max and back into InfraWorks it would be nice to have a way to set a standard offset value for exports in the model parameters so each export is constant and all users use the same offset. To ensure a consistent offset each time we export or import we save the offset values in a txt file and copy and paste on each export or import if there is no pos file. Additionally it would be nice if civil view in 3ds max would read pos files to set the global shift inside 3ds max to ensure that data added to 3ds max from civil 3d is shifted correctly also and data from all three programs shift correctly.
1 Comment
Eric_Chappell
This is a great idea but it hasn't gathered a ton of of community support. We'll keep it on the list though under Future Consideration.
