Component Rail Command
Ideally this would be a full-fledge 'just as good as the component road', but even in the interrim; It 'should' be easy enough to just made a new button called component rail that calls up the same road command but with different defaults on it.
Makes users feel that Infraworks is indeed the correct software they should be using for Rail projects
