Combine two parts of component roads
In some cases you have to combine or put together two parts of component roads with the same style, the same components and the same definitions to one road with one ID, one name etc.
You can do it manually, also with the Profile view, but it is quiet difficult and there is often still a hole between these two compontent roads.
A "Combine-command" like for the line extraction from Point Clouds would be helpeful.
