InfraWorks Forum
Welcome to Autodesk’s InfraWorks Forums. Share your knowledge, ask questions, and explore popular InfraWorks topics.
Tunnel Intersection
3 REPLIES 3
aaron047
695 Views, 3 Replies
Tunnel Intersection
How do you model a widening within a tunnel structure that exits with an tunnel? Can you do tunnel intersections? If so how?
Cheers
A
3 REPLIES 3
Karsten.Saenger
in reply to: aaron047
Hi @aaron047 ,
tunnel intersections are not (yet) supported in InfraWorks, the same a bridge intersections.
But it's on the list for future enhancements...
Karsten.
Karsten Saenger
Have you found a decision?
nkiakas
Hi @aaron047
I have exactly the same problem as you.
I tried to create a "structure" intersection first with bridges and looks like it worked in IW2022. Not perfect, but worked.
When I tried to create an intersection of two tunnels.Did not work. One tunnel wall is inside the other.
Then I used civil3d. I created a custom "half tunnel" subassembly with ASC.
I exported the corridor in IMX and imported it to IW. The result is the attached picture.
Still need a lot of o work to make it a proper tunnel, because IW considers this as roads, and it's not under the existing surface. It Just shows an open cut
Does any have any suggestion, please?
Rail Community
