to Move the model
to Move the model
bhaskar_nitw
to Move the model
bhaskar_nitw
Is there any option/ method in Infra works to Move the road model from the existing position to the new position in the same model file.  Please refer to attached  snap shot. I want to move the model in Yellow box to new location circled in blue color.
Bhaskar
Bhaskar
Hi Bhaskar,
Can you select all of the roads by holding 'ctrl' while you select them?  When you've got them all selected you should be able to shift them using the move gizmo.
Hope that helps,
Harry
bhaskar_nitw
Thanks Harry.
It is working. 🙂
Bhaskar
Karsten.Saenger
Autodesk Support
Autodesk Support
Hi @bhaskar_nitw,
you should also be able to "copy" features and paste the in a different place.
Or export an IMX to Civil 3D, move there to the new position and re-import them to InfraWorks (IMX, Civil 3D DWG).
Karsten.
Karsten Saenger
bhaskar_nitw
Thank you karsten.
Bhaskar
